Brake compensator regulator valve adjustment
(In Topic #224200)
![G60RGE in the usergroup ‘Old timer’ G60RGE in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
if this is the case which direction does what?
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
abfmk1 said
When its all together its quite obvious, the theory being more weight in the rear (which requires more braking) compresses the suspension and the spring pulls on the compensator lever, which opens the valve to let more fluid/pressure through. I guess the starting point depends on the level you run the car…
il put it roughly in the middle and drive carefully until i find a quiet test road
so there is o adjustment on the actual valve itself?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
to be fair, somethings are best left alone especially when they are rusty
is there a basic function test i can do before fitting?
i guess it kinda works
