Anyone built up split rims themselves
(In Topic #223699)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Colour Centre poll
Recently became the proud owner of some Schmidt TH lines 14x8 and 9
Plan is to get the barrels and faces refurbed while I have the lips mirror polished and any imperfections removed.
Only problem is they came with only 2 bolts holding them together so I need to source some.
Can I use ordinary stainless allen bolts with nuts?
I'm planning on building them back up myself so if anyone has any hints and tips on sealing them and indeed suggestions for the centre colours I'd be very grateful
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/108image.jpg)
![Smig1003 in the usergroup ‘Paid Member’ Smig1003 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Smig1003 in the usergroup ‘Local’ Smig1003 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Current rides:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Get some good advice on whether stainless are ok to use as stainless can be brittle and when being used in shear can break.
Just something to consider.
I was going to suggest that Mister T might be able to assist Tyre valves
But looks like he doesn't do wheel building bolts. Might be worth considering for valves and actual 'holding to the car' bolts.
As it's a black car you could go mad with the colour of the wheels. How a bout a deep candy red or a brandy wine type colour?
Depends on how much you want to stand out I suppose. Or match the wheels to an intake, engine bay or interior accent colour?
Have fun
Ian
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
I did consider though that due to there being 20+ bolts per wheel and them all being such low torque setting that hi ten steel probably wasn't going to be necessary although I will check first
Current rides:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2C8C2DD32-C516-488E-9E1B-1D4EC3BD7E6C.jpeg)
![benandemu in the usergroup ‘Paid Member’ benandemu in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![benandemu in the usergroup ‘Local’ benandemu in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Bolts should be available from Schmidt direct. If you can't get them, then try RSFelgenin Germany. Their website is worth a drool anyway.
1980 Mars Red GTI BRMotorsport 142
1983 Black GTI
1983 Black GTI
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2C8C2DD32-C516-488E-9E1B-1D4EC3BD7E6C.jpeg)
What have you previously used, as I'm also considering the corrosion side of things
Current rides:
BBS were very specific with me, as was Roland Gamperling from RS Felgen.
1983 Black GTI
1983 Black GTI
Majority of stainless is A2 grade but split rim bolts should be A4-70 or A4-80, the later is slightly stronger but not enough to make a difference in a split rim m6 application.
Its actually quite interesting to read that pretty much all split rim manufacturers specify a torque rating higher than the bolts are actually recommended to take, which means in short they will stretch to a degree so you should never ever buy secondhand split rim bolts
Current rides:
I have genuine BBS bolts on mine, and they state 10.9 on the head, which I assume is referring to its tensile rating.
It's not a great photo, but you just about make it out on this pic.
![657C3EB5-960E-4D13-B781-506B661C474A.jpeg 657C3EB5-960E-4D13-B781-506B661C474A.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1586979834/uploads/attachments/5e9763f96b60b.jpg)
10.9 is quite a high strength but because the bolts are so small only a small amount of torque can be applied to them which greatly reduces the forces they can take anyway
Current rides:
