I keep having to replace my ignition coil!.
(In Topic #223727)
![Seemit in the usergroup ‘Newbie’ Seemit in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
No spark and having to replace coils alot
I recently bought a 1986 mk1 rabbit 1.8 carb and I'm having issues with getting it started.
It cranks but not getting spark. Changed the bogey cords and the coil a good few times. Each time everything works but the min the battery gets disconnected (the car still a work in progress) and reconnected I dont get spark to any of the plugs.
I did have the wiring harness replaced. Is the car maybe not grounded correctly or is the coNections on the coil not connected properly?
Please help.
Last edit: by Seemit
As a test, you can take a pair of battery jumper cables and attach one from the negative battery post to frame ground, then the other from the negative battery post to the engine.
