1.8 Injector threads
(In Topic #223261)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/347598347539845.jpg)
![Mr_Resist0r in the usergroup ‘Newbie’ Mr_Resist0r in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I've only just found this website and have created an account so I apologise if I’m not in the right forum. I recently acquired an old 1984 mk1 1.8 cabriolet in white which I've managed to get going. One problem that I've managed to diagnose is that the injectors are full of **** and the seals are knackered. So, I went on eBay and got some replacements, all sounds good so far. As I went to install the new injectors I noticed that the threads are different
![:(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/sad.png)
is there a conversion piece or a washer that can bridge the gap and thread into each different thread on both the injector and the fuel line?
've got a brand new set of injectors that are useless to me if not…
![:'(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cry.png)
![20200221_163824.jpg 20200221_163824.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1582395825/uploads/attachments/5e5171af446b0.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
lhasadreams said
Welcome. Two different threads were used.
You can either get the correct ones or get a set of the fuel lines that match your replacement injectors.
Thanks for the welcome, I thought this might be the case
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/received_10212253851841257.jpeg)
![Kenneth Cartwright in the usergroup ‘Paid Member’ Kenneth Cartwright in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Kenneth Cartwright in the usergroup ‘Local hero’ Kenneth Cartwright in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Oops scratch that..the hoses I have are for the larger 12mm thread..
https://www.classic-vw.co.uk/mk1-golf-gti-k-jet-fuel-injector-hoses-7pc-set--1121984-4896-p.asp
https://www.classic-vw.co.uk/mk1-golf-gti-k-jet-fuel-injector-hoses-7pc-set-1121984--4912-p.asp
Last edit: by Kenneth Cartwright
On the drive
Myvalver 89 GTi Grey mk2 16v
![cedar in the usergroup ‘Old timer’ cedar in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I would think you are better off returning them and getting a set to match the originals.
https://www.reflectionsandshadows.com/cis-injector-cleaning/
Berrymans is dabomb
the flow rates etc are the same either way no problem using them with new lines if thats what you want to do.
if you do decide to return them look for the mecedes/ferarri brass ones on ebay often can be a little cheaper than original steel type and are non-shrouded coarse thread type so a direct fit to your car
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/2avatar2.jpg)
![paceman in the usergroup ‘Paid Member’ paceman in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![paceman in the usergroup ‘Old timer’ paceman in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Do you mean ones like this? https://www.ebay.co.uk/itm/333387853750
Are they like for like on an 83 k-jet? If so, that's a cash saver right there!
Cheers,
J
this seller has a 20% off code as well
https://www.ebay.co.uk/itm/333500320540
rubjonny said
yep thats the one, same thread, non-shrouded. direct swap
Are there no difference with things like opening pressure?
the irony of a Ferrari part being cheaper than a Classic VW part is not lost on me!
