Water pump pulley catching plastic cam belt cover!?!?!
(In Topic #223191)
![cdgthreesalmons in the usergroup ‘Paid Member’ cdgthreesalmons in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![cdgthreesalmons in the usergroup ‘Old timer’ cdgthreesalmons in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
When I came to fit the water pump pulley to the new (Meyle) water pump - I find that the pulley catches/rubs on the plastic lower cam belt cover…..
I am sure the plastic cam belt cover is properly seated and there is no tolerance for alignment on the water pump bolts. I can see clear witness marks from where the pulley has been rubbing the plastic previously.
Anyone had the same issue.
I note in the forum guide the same problem occurred. They used some washers between the water pump flange and the rear of the pulley to gain enough clearance.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=how-to_2%2Fguide-changing-your_7
Step 40 - My new pump made the pulley sit too close to the timing cover so I had to space it with washers as shown
I would have thought this would have put the v-belt pulleys out of alignment and caused a problem with the belt - either noise/increased wear.
Advice greatly welcomed.
![DSCN1061.JPG DSCN1061.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581534953/uploads/attachments/5e444ee8f0d2c.jpg)
![DSCN1062.JPG DSCN1062.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581534956/uploads/attachments/5e444eeb5f0f4.jpg)
![DSCN1063.JPG DSCN1063.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581534958/uploads/attachments/5e444eed41d35.jpg)
Clear evidence of previous rubbing
![DSCN1060.JPG DSCN1060.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581535050/uploads/attachments/5e444f49723c7.jpg)
![](https://s3.photobucket.com/user/briano1234/media/waterpump/S5030969.jpg.)
![](https://s3.photobucket.com/user/briano1234/media/waterpump/S5030971.jpg.html)
![Screen Shot 2020-02-12 at 3.07.41 PM.png Screen Shot 2020-02-12 at 3.07.41 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581538118/uploads/attachments/5e445b4568f4b.png)
![Screen Shot 2020-02-12 at 3.04.45 PM.png Screen Shot 2020-02-12 at 3.04.45 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581538124/uploads/attachments/5e445b4b970d8.png)
![Screen Shot 2020-02-12 at 3.05.20 PM.png Screen Shot 2020-02-12 at 3.05.20 PM.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581538128/uploads/attachments/5e445b4f76695.png)
The pump is a MEYLE: part number 037 121 0101C which is correct for the 1.8DX
Piccy of the water pump.
![DSCN1065.JPG DSCN1065.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581543075/uploads/attachments/5e446ea1cd03a.jpg)
to check this fit the v-belt and see if the waterpump pulley is sat too far in compared to the crank pulley
either way fir the v-belt and check its alignment. if its offset too close to the block the waterpump is incorrectly made so you need to send it back or pack the pulley out with a spacer to fix the problem
Cam cover: 049 109 175
OEN 026 121 010 – VW
OEN 026 121 010 C – VW
OEN 026 121 010 F – VW
OEN 037 121 010 – VW
OEN 037 121 010 A – VW
OEN 037 121 010 B – VW
OEN 037 121 010 BX – VW
OEN 037 121 010 C – VW
Do the water pump pulleys vary?
I see the parts list number for the DX engine is 049121031 - but other engines have different part numbers???
I see Mark at CVW sells Water Pump Pulley, 026121031 which is only for the EW/HN engines?
Heritage sell the same pulley stating for 1.6/1.8 models??
Any advice very greatly appreciated.
rubjonny said
see the flange that the pulley bolts to on the waterpump, this is actually a press fit on the main shaft on a genuine pump. what it looks like is the flange has been pressed onto the shaft slightly too far, or if its one piece has been incorrectly manufactured.
Thanks Rub, I couldn't explain the reasoning for the extended shaft….I guess.. but that was what I was implying….. I have never had an issue with Water Pump Scraping the Covers, so I was inferring to the water pump mount being in the wrong position… which you nailed…for my lack of explanation… I suspect that with the correct pulley remover he could get it out a few mm to clear to make things happen…
Also if it has a plastic impeller you might want to exchange it for a metalic one.
its worth a look at the other bits but I recon you're on the money with incorrect offset on the pump just doesnt look right
I had a similar problem with slight rubbing on plastic cover theres a little movement when bolting it down and I still had a cut a little grove out of the cover to stop it rubbing. The belts been fine for the last couple of years
![Pistol in the usergroup ‘Paid Member’ Pistol in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Pistol in the usergroup ‘Old timer’ Pistol in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![5da7a527b052e.jpg 5da7a527b052e.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1581717186/uploads/attachments/5e4716c0eb7ec.jpg)
Regional Host NE
instead of doing a bodge job
https://volkswagen.7zap.com/en/rdw/
Thanks rub
I've been away from the car for few a days so intend to check this alignment 1st thing in the morning.
mark1gls said
Meyle pumps have a metal impeller as I fitted one A couple of years ago.
Certainly seems to be a problem a few people have - with rubbing. I will check the pulley alignments tomorrow.
Pistol said
I have a Meyle water pump also, fortunately I don't have any rubbing. However, if the rub is only slight, could you not just put a packing washer under the pulley at each bolt location just to space it out enough to clear the cover? I doubt this would affect the alignment of the belt too much.
Thanks Pete I will check tomorrow on alignment etc. However having fitted a brand new quality pump, and having taking great time and care refitting all the parts like the plastic cam guard I surely the pulley should not catch. Unfortunately I cant find a part number on the pulley - maybe that is at fault?
nicci21paul said
why not fit the belt cover correctly
I thought the belt cover was fitted correctly and I certainly don't want to have a bodge job!
Briano1234 said
Looking at it more and a bit more that doesn't look like the right pulley…. Get the pulley number, and then look up your engine on the ETKA for the correct pulley.
As mentioned above I cant find a part number on the pulley unfortunately.
