Dash removal - cabrio
(In Topic #222177)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/E51CC3C6-51F7-4094-8C4F-1CE789C8DE56.jpeg)
![](https://uploads.tapatalk-cdn.com/20191005/904ea448ed6dd013cb36777157c83770.jpg)
Hi all - as you can see I have a rather large welding job to do
![](https://emoji.tapatalk-cdn.com/emoji29.png)
I’ll need to remove the dash for this, so I’d like to ask for advice from anyone who has removed a dash from a mk1 cabrio - as I don’t want to remove more than I need to,
So far I’ve removed the steering wheel and dash fascia , what’s the next steps ??
![](https://uploads.tapatalk-cdn.com/20191005/a3fa4999e24b2bd00e623caaec85a6b3.jpg)
Cheers!!
If the lower part of the dash is stillscrewed to the knee-bar there are about 3 screws that have to be removed.
![](https://i3.photobucket.com/albums/y65/briano1234/Dash/dash.jpg)
remove the 2 screws holding the heater controls.
remove the center vent or ash tray
To safely remove the center vent make 2 wire pulls bent as shown.
![](https://i3.photobucket.com/albums/y65/briano1234/heaterventpull/DSCI0071.jpg)
Insert them in to the center vent at the corners and turn them to catch the rear of the vent and pull out.
![](https://i3.photobucket.com/albums/y65/briano1234/heaterventpull/DSCI0072.jpg)
![](https://i3.photobucket.com/albums/y65/briano1234/heaterventpull/DSCI0074.jpg)
Then Pull the dash to the rear of the car to release the windscreen clips, then lift up and over.
![](https://uploads.tapatalk-cdn.com/20191006/c2e93bedd7dbf2238c6f5503123704f5.jpg)
Nasty little buggers going in to the bottom of the two white brackety bits you can see
![](https://emoji.tapatalk-cdn.com/emoji106.png)
![](https://uploads.tapatalk-cdn.com/20191006/16d2dc7505d2345842bf9384be230665.jpg)
![](https://uploads.tapatalk-cdn.com/20191006/5431ca090e535fdee5b74977ff72bce8.jpg)
