"TAG" - 1983 Campaign restoration blog
Firstly mounted it on a stand - such a useful piece of kit for engine work.
I managed to get a socket & iron bar to stop the crank turning, applied some heat to the rounded heads and banged a spline headed socket into the damaged head - and voila!
Again the most difficult stripped but managed to use the same trick as on the bottom belt pulley bolts.
I had the manifolds soda-blasted (well worth it!!!!) and then I painted them in high temp paint……..followed by a few hours in the oven. Family not impressed ………….. you could certainly tell it wasn't roast beef from the aroma!!!
Before and after soda-blasting - exhaust and intake
Looking better than good roast beef…….??????
Before
After
All looked good on strip down. I am taking the block for checking/honing to a specialist engine tuner. He is also going to port the head along with other head work. At the same time his gearbox man is going to overhaul my gearbox.
I wish, I wish I had the space and equipment that you have when I did mine.
Throttle body as removed from car
