Front indicator fault
(In Topic #221290)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20170805_180530.jpg)
![marcsa3 in the usergroup ‘Local’ marcsa3 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
The bulb and bulb holder are both good and the wiring from the lamp to the plug on the slam panel is all in order.
Electrics and me are not a good combination and a friend mentioned it could be a relay problem but I've come to a dead end here as my knowledge in this area is pretty phoeble.
Any help appreciated.
Marc
1990 Golf GTI cabrio 1.8i. DX Engine
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/224image.jpg)
![Mike 16vG60 in the usergroup ‘Paid Member’ Mike 16vG60 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Mike 16vG60 in the usergroup ‘Old timer’ Mike 16vG60 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Is the earth good?
Unfortunately thats the extent of my electrical knowledge.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I found when I fitted tinted ones that the plugs on the back didnt give a great connection into the factory wiring
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
I do know that I am anal about getting bulbs with Brass Bases versus the Steel Bases. I have heard that they are spraying a coating of lacquer on the steel ones that may have to be sanded off to make good contact.
Most issues I have had are corroded or worn sockets.
In the HELP section of our parts stores here you can buy replacement sockets and springs to renew the internals.
I can remember on my 81 diesel that I ended up soldering new and taller pads on my sockets to make better contact… and using the Brass Based sockets on the bulbs.
