Gap between tyres & suspension
(In Topic #220833)
![0337 in the usergroup ‘Paid Member’ 0337 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![0337 in the usergroup ‘Old timer’ 0337 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1549575717.jpg)
![gafo in the usergroup ‘Old timer’ gafo in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![20180208_143749.jpg 20180208_143749.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1556049091/uploads/attachments/5cbf6cc0b3f71.jpg)
Sounds familiar, coilovers and 195/50 doesnt work.
To be honest I dont think 195/50 works on the mk1 anyway
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
spacers will help move the wheel out but to will need to watch the other side…
The back end has a lot more inner
Current rides:
![20180821_173317.jpg 20180821_173317.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1556052649/uploads/attachments/5cbf7aa7db684.jpg)
This is an 8" wide rim with an et25 offset.
To make it rub would probably need a 205 tyre
Current rides:
I'd like to think not with a 6" rim on an et35-38
But a 185/60 is going to give you a bigger rolling radius over 195/50 and will cause the tyre to balloon quite a bit outside the width of the rim so I think you may still have clearance issues with the tyres.
Why such big rubber?
Current rides:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/AvatarUploadedByTapatalk1451991667.jpg)
![volkswarren in the usergroup ‘Paid Member’ volkswarren in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![volkswarren in the usergroup ‘Local hero’ volkswarren in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Could have 15” if later cabbygafo said
Thanks mate, I thought 185/60/14 tyre was the correct size for mk1s as fitted by vw?
185/60/14
185/55/15 depends on wheels fitted.
But common tyre upgrade was 195/50/15.
Regards Volkswarren
The later cabs with BBS RA rims (I think thats the right model) would of been 195/50 but obviously on standard suspension
By modern standards it just sounds a bit wrong, almost like the lack of quality in the rubber back in the 80's was sorted out by putting more of it on the road.
With modern tyres now you can have 3/4 of the original contact with the road yet still have more grip but it all depends on what you want aesthetically and comfort wise but I am making the assumption if you are running coilovers then ride quality isnt a priority anyway
Current rides:
Is there enough space on the other side to space the wheels out at all?
Failing that go down a tyre size
gafo said
Are Coilovers really that bad ?I switched the boge gas shocks and weitec springs from the tin top onto my cabby as I plan to sell the tin top and the suspension was shot in the cabby anyway.
From my own experience yes unless you can spend £600+ but I've not had the pleasure of trying that yet.
Personally I think the Mk1 is too light a vehicle for coilovers, same on my Mk3 polos.
Where as I've just fitted Stance coilovers to my E46 BMW and it rides beautifully
I've gone to AP racing shocks and springs, its low enough but comfy
Current rides:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Either use a 5 to 10mm spacer or get different wheels.
You could drop to a 185 tyre but that would only give 2 to 3mm extra clearance.
If you go with spacers anything over 5mm wide and you'll need longer bolts to hold the wheel on.
Original tyre specs were 185/60 r14's with a wheel of et38 on the steels with a width of 6 inches.
If you wider then you need to take into account that the ET changes as well.
Coilies vs shocks and springs! The debate rages.
Cheap are rubbish whether Coilies or shocks n springs.
Ian
gafo said
Good man Ian, you’re a wealth of knowledge, so is it possible my collies won’t rub if I use highest set up and my p slots with 175/60/14 tyres?
You should be fine as any coil overs with the car on it's factory size wheels, you should be able to get away with 185/60/14 on P slots as that's what VW fitted as standard.
