Extra wires and plugs on my 81 1.1 golf L
(In Topic #220772)
![gnfnr88 in the usergroup ‘Paid Member’ gnfnr88 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![gnfnr88 in the usergroup ‘Local’ gnfnr88 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I have got myself another golf. Its a 81 5 door 1.1 L model. I will put in the project section when i eventually start on it.
Please can someone help me with a few bits first. As the previous lads that owned it have had a fiddle.
Its non servo master cylinder with 2 sender units but what plugs into them
![20190412_170946.jpg 20190412_170946.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444102/uploads/attachments/5cb631825e105.jpg)
Theres 2 wires taped up here
![20190412_170958.jpg 20190412_170958.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444106/uploads/attachments/5cb63188a29d5.jpg)
There on the same harness as these.
![20190412_171009.jpg 20190412_171009.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444109/uploads/attachments/5cb6318bafc64.jpg)
Also what are these wires for
![20190412_171139.jpg 20190412_171139.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444112/uploads/attachments/5cb6318eb94e5.jpg)
![20190412_171131.jpg 20190412_171131.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444115/uploads/attachments/5cb6319222509.jpg)
![20190412_171054.jpg 20190412_171054.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444118/uploads/attachments/5cb6319562ea7.jpg)
And should i have these because they werent on my other golf (78 1.1 golf N) and i have no plug for them.
![20190412_171157.jpg 20190412_171157.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555444122/uploads/attachments/5cb6319880837.jpg)
Help as usual much appreciated
1989 helio\'s blue clipper
Is it possible that I use the 2 taped wires on each sender unit then join a wire linking them.
![EasyPhotoEditor_16042019_222814.jpg EasyPhotoEditor_16042019_222814.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555450246/uploads/attachments/5cb6498463cfb.jpg)
![EasyPhotoEditor_15042019_224141.jpg EasyPhotoEditor_15042019_224141.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1555450465/uploads/attachments/5cb64a6063053.jpg)
The car is august 81 so no servo and m/c on the driver's side so it can't be the same red/yellow red/black wires.
The wires for the 2nd switch are crimped into the pins for the 1st switch. So the 2nd switch piggybacks off the first if you get me, wire colours are red/yellow and red/black for both switches.
the taped up wires are probably for the original carb, you have a later engien so you need to do a little adaptation to get it all sorted. the red plug in coolant housing is the thermoswitch for the inlet manifold heater, this would have an ignition live to it plus a purple/black back to the fusebox to trigger the inlet heater relay. the output from this relay is a thick white/red which then plugs into the inlet heater on the bottom.
The 2nd sensor looks blue? if so the engine used to be an SPI unit with an ecu, the blue sensor being coolant temp for the ECU. If its now running a 2e3 or similar carb you'll need to change it for a grey thermoswitch which then triggers the autochoke, or if its a basic weber or similar no need to worry.
the thick red/black from fusebox is for the starter motor, thinner red/black may be radiator fan related?
As usual your a lifesaver (i you had a penny for everytime you heard that you would be at least a millionaire mate).
I was starting to worry that the master cylinder had been moved to fit the expansion tank and thats why the wires were that side. I shall get a connecting wire sorted.
The rest i shall have to take in as my brain cant take that much info in one go.
The carb is the 1e1 pierburg with manual choke but there is an auto choke version in a box in the boot, i will leave the manual one on for the minute at least till i get the car up and running.
Are the taped wires attached to oil temp and pressure senders.
![20190423_153318.jpg 20190423_153318.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1556039741/uploads/attachments/5cbf483a434a6.jpg)
The one thing i did check is the starter motor has its connecting wire from the loom at the back (thick red/black)
![20190423_153407.jpg 20190423_153407.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1556040157/uploads/attachments/5cbf49dc11ed4.jpg)
so i am still not sure what the front red/black wires are would they be for the fan thermoswitch
![20190423_153229.jpg 20190423_153229.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1556040161/uploads/attachments/5cbf49dfdd0ca.jpg)
And lastly the second sensor is black for some reason it does look like a dark blue but im sure its black. Is there any markings on the engine that will tell what the engine is (ie. Code, stamps etc…) so i can at least date it.
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=technical%2Felectrics_2%2Fextra-wires-and-plugs
fan wiring looks right, you should have a permanent live from the fusebox to the fan switch then other pin goes off to the radiator fan, 2nd pin on fan is earthed.
with the oil switch blue/black wire now I think about it is probably for the low pressure switch 0.25 or 0.3 bar, which triggers the oil light ignition on and if oil pressure drops while idling
engine code is stamped into the block just above the gearbox bellhousing, if you're lucky it might still be readable:
![](https://workshop-manuals.com/volkswagen/golf-mk3/images/golf-mk3-4441.png)
If there is a VW part number on the distributor I can tell you what thats off at least.
