Tonneau cover
(In Topic #220598)
Merchandise Manager
Sorry about out the bad photos ☹️
Hopefully someone can help.
There is a popper each side (one of mine had snapped and was inside the cover
Finally when you put the rear seat down there is 2 indents in the plastic at the sides of the seat
Should be 2 bits of elasticated material on the cover with hooks on the end to go into them
Oh and the velcro straps to drop into the boot and go onto the bottom of the parcel shelf
Current rides:
There are also issues that the straps under the parcel shelf don't hold the velcro. I have added a snap to them and affixed the male part to the Parcel shelf with a screw.
Lastly there are the elastic cords with a snap that hold the inner edges of the plastic wheel well cover. The do get stretched out and need to be replaced.
There are also differences between the early 80=81 Cabriolet Frames that they sit higher and you may have the improper boot on the car for the frame as the frame has been changed.
Check it's down correctly, then fit loosely over hinges, pull back down towards where loops and wire hooks should be. Fit front 2 press studs 1 each side. The big loops in rear I dont have all elastic I put 2 marker pens through and that stops it been pulled out .
On the drive
Myvalver 89 GTi Grey mk2 16v
