Cabriolet roof not closing properly
(In Topic #220581)
![0337 in the usergroup ‘Paid Member’ 0337 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![0337 in the usergroup ‘Old timer’ 0337 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Are your eccentrics adjusted correctly, and then when it stops at the 2-3 inches is it fairly easy to close and latch?
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Eccentrics won’t do a deal they’re to stop the frame from mashing the tops of the B pillar seals.
Are you saying the car has had new roof or old roof has shrunk yes they shrink but not to where you couldn’t close roof.
I’m over in Derby East Midlands if you can get over I can have a look.
![](https://uploads.tapatalk-cdn.com/20190328/b01111a1bdc7d53c863b86720d6eff44.jpg)
Should be a picture where to oil here and lots more info you might want to read…
Left hand side column is a tab, lubing the frame.
Convertible Top
Your fluid must be between the min and max lines on the reservoir with the roof in the down position.
Open the hex filler but 13mm and try and draw some fluid out so it’s at the correct level.
Or install Tapatalk and add the MK1 Golf Owners Club.
It works better than the site for uploading stuff
