Golf cabriolet A pillar trim
(In Topic #220577)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/245690D5-B533-44EF-BA7E-7D474833457A.jpeg)
Merchandise Manager
![Anton_cabby in the usergroup ‘Moderators’ Anton_cabby in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Anton_cabby in the usergroup ‘Paid Member’ Anton_cabby in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Anton_cabby in the usergroup ‘Local’ Anton_cabby in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![D53D1C07-0557-43E7-805D-18097E4DF089.jpeg D53D1C07-0557-43E7-805D-18097E4DF089.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1553717480/uploads/attachments/5c9bd8e7b4fc9.jpg)
Regional Host NE
find mate got three mk1
golfs standing not one has
one of any use left or right
all cracked
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20140817_134137.jpg)
![scotty b in the usergroup ‘Paid Member’ scotty b in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![scotty b in the usergroup ‘Local’ scotty b in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Golf 1993 clipper
Audi A3 S line Quattro
Merchandise Manager
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=newbies_2%2Fmk1-cabby-finally-back
If that's a picture of your car then your side tension cables have broke or you roof has shrunk as you should see that much of the inner pad or plastic trims on the side of the roof.
You can replace the side tension cables with the roof still on the car buy carefully pushing them through the side roof channel but it's fiddly.
Merchandise Manager
Saying that I when through a whole summer without opening my roof as it was tearing when folding down flat, gaffer tape was my friend that year..
Depending on how handy you are there's a good guide on here to replacing a roof as a new roof is £200 but you need to add stapes, foam gasket, high heat contact adhesive, window sealant, rear and side tension cables.
The metal rear window frame will need repainting at the very least as you want to last as long as possible as they are silly money…
Guide here to what's involed.
Cabriolet Hood Replacement - The Mk1 Golf Owners Club
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/45359305-11DA-40FC-BA00-CF40CC53E660.jpeg)
![Jon H in the usergroup ‘Paid Member’ Jon H in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Jon H in the usergroup ‘Regular’ Jon H in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
scotty b said
I got mine from werks34.de mate arrived in 1 week
I'm looking for some of these too - do they look the same? I'm trying to keep my car as original as possible.
Cheers!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/C5FAA5CB-7092-491D-B0B8-2EA60A105602.jpeg)
![Kingy76 in the usergroup ‘Local’ Kingy76 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Hi Scotty B
How much work was it to fit your werks34 a pillar trim to make it look good?
Mine has arrived and it appears to be a mare to fit and make it look similar to the standard on the near side of the car?
![KenExRN in the usergroup ‘Regular’ KenExRN in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
I’ve decided to remove my near side trim and leave the car without the 2 trims as I’ve seen other cabs without them and they look alright and I know if I change my mind I’ll find some used versions again in the future.
Don't blame you for sending it back though because they are certainly not that great and if they were the correct length and the bottom had the correct curve I doubt if they would ever go on.
I'll let you know if successful or not and keep my eye open for any that come available for you.
