Best way to Descale water pipe connections?
(In Topic #219950)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/WhatsApp%20Image%202019-08-22%20at%2008.jpeg)
![h3lter in the usergroup ‘Paid Member’ h3lter in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![h3lter in the usergroup ‘Local’ h3lter in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Systems already drained
Took the suspect pipes off after draining system and have scraped off 80% but before reconnecting what's the best way to clean them up as much as poss?
I've got normal kettle descaler etc but it's the type you stick in kettle and let it boil to clean so can't see that helping
What's the best thing to use on the engine with what I suspect would be a toothbrush?
Cheers all
Nath
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1547291827/uploads/attachments/5c39ccb1d71b2.jpg)
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1547293127/uploads/attachments/5c39d1c414a3c.jpg)
https://www.vwheritage.com/026121144e-coolant-flange-with-o-ring-vw-spare
to flush and back flush a system see my how do I do that thread in the archive section how-to's briano's 90 cabbie post.
Or click the link in the signature.
![FD4EB016-71E3-43CF-A1DC-A7B478D64BBE.jpeg FD4EB016-71E3-43CF-A1DC-A7B478D64BBE.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1547299866/uploads/attachments/5c39ec1906e4b.jpg)
When fitting new bolts back in smear them in copper grease and it will stop the aluminium to steel bolt seizing together which happens over time.
Good luck and let us know how you get on…
Last edit: by mark1gls
Do I remove head to remove these bolts? They are flush now as flatting and using adjustable sapped them further
At bit of a cross roads
I know it's a pain but if it was me I would take the head off but you will need new gaskets etc.
Have you had the head off before?
If not might be a good time to change valve steam seals as they go hard over time and check the valves, valve guides, cyinders etc…
Up To to you really?
Perhaps others will offer advice etc….
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1547305419/uploads/attachments/5c3a01c97473a.jpg)
Yea got the spline tool, had enough for one day tho tbh 😂😂
Will keep you updated.
The plus sides that once head gasket replaced and cambelt is done (luckily the one I bought I hadn't fitted yet) I've pretty much replaced all the big boys. Oil pump was one of first jobs. I'll get water pump too as might as well get that done now too.
At least she will be ready for the big runs to the more distant shows. Was only going to go localish
Might be worth asking them to test and clean the head while it's off?
If you strip it complete it's only about £30 to get them to put it in their big dishwasher and you get a nice clean head….
If you do strip the head yourself make sure you keep all the valves, spring etc in the right order so they all go back in the same place.
Got a few days hol to take before April so might invest a couple into her
At least you can have a good check inside the engine when it's apart.
I smear a little high temp grease over the ends of the metal flanges when refitting the rubber coolant hoses as this seems to slow down the pitting/corrosion and makes it easier refitting/removing the hoses.
I also use ready mixed coolant as tap water is not the best when mixing coolant, I use the blue stuff that needs changing every couple of years.
https://www.eurocarparts.com/ecp/p/car-accessories/engine-oils-and-car-fluids/antifreeze-and-screenwash/blue-antifreeze/?523770501&0&cc5_865
Fuel injector inserts…
Depends on what type you have, I had brass coloured metal tops and the bottom part was plastic which a few bits had fell off… I just cleaned up the metal part and fitted new plastic bottoms, pig of a job to get a couple of them out and they fell apart so not the sort of job to do when the heads on the engine..
https://www.ebay.co.uk/itm/4-x-New-VW-Golf-GTI-MK1-MK2-1-8-16V-Corrado-Lower-Fuel-Injector-Inserts/151567468047?hash=item234a20060f:g:VoMAAOSwT5xZOz2V
![Steve1973 in the usergroup ‘Local’ Steve1973 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
https://i47.photobucket.com/albums/f197/mark1gls/Golf%20engine%20rebuild/CIMG9035_zpsjla52nhf.jpg
Then with new plastic bottom inserts.
https://i47.photobucket.com/albums/f197/mark1gls/Golf%20engine%20rebuild/CIMG9081_zpsdy5rqdzd.jpg
Fitted.
https://www.vwheritage.com/063133555a-insert-for-fuel-injector-18-vw-spare
Or the metal top..
https://www.vwheritage.com/034133555a-upper-insert-for-fuel-injector-16v-vw-spare
I have had good success with smaller left-handed drill bits and a reversible drill.
But I would be dam sure that you get it center punched and use a bit that is about 3/4 the diameter of the bolt and soak them with pb-blaster for a few days.
if you are going to remove the head you might as well replace the timing belt and tensioner as well.
