No heat from passenger vents, but heat from windshield vents
(In Topic #219515)
![bunny_man in the usergroup ‘Newbie’ bunny_man in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Thanks.
www.cabby-info.com has a mod where you insert a metalbestos tube cut some holes and have heat out of the side vents, but by nature what you are describing is "Normal".
The A/C equipped car looks like this under the hood
![](https://i3.photobucket.com/albums/y65/briano1234/heater%20vent/heater008-1.jpg)
It is controlled by vacuum servos and the Center vent servo operates by defrost as a default. It has a tendency to go bad, and leak, and you get no air blowing out of the center vents at all. To replace it you have to take your dash apart well the Upper Dash out.
The non-a/c equipped is operated by a cable.
![](https://i3.photobucket.com/albums/y65/briano1234/heater%20vent/heater.jpg)
Cheers!
