Newbie in the market to buy - advice needed please
(In Topic #219391)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/forks.png)
![Crowey26 in the usergroup ‘Local’ Crowey26 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Mark 1 GTI convertible wanted - where to start
thanks for clicking on my message
my first car was a mark 1 L A reg and I loved it - 20years on and I have a few quid and want to treat myself after a change of personal circumstances
As I write this message, part of me is rather intimidated by the process of buying a mark 1gti convertible, as unlike many of you I have little knowledge of what to look for nor indeed the skill to maintain such a vehicle -gotta start somewhere I guess
here is my brief:
USAGE: daily runner for short local drives, occasional longer runs at the weekend. I have two children so lap seats may need conversions to cater for booster seats
(we have a modern family car already)
Car must be reliable, and dry (my old car leaked terribly but I never had the money to solve this)
i do t have a garage sadly but would buy and use a car cover to keep protected.
BUDGET: circa £7k willing to spend a bit more if needed
CONVERTIBLE? It seems the value lies in the hard tops (do correct me if I’m wrong) but I think I would prefer a convertible
Keen in the later 88-92 models
can you guys help me? what should I look out for ? Perhaps there are a top 5 or 10 tips you can share with me so as I start to visit sellers I a mark a little more informed.
really appreciate any help
Adam
Last edit: by Crowey26
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/greenman.jpg)
![borednow in the usergroup ‘Moderators’ borednow in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![borednow in the usergroup ‘Regional Hosts’ borednow in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![borednow in the usergroup ‘Local hero’ borednow in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
There's a buying guide on the site somewhere that'll help you out but the main thing to check for is rust.
Good thing is there's lots of spares out there now so if anything breaks it's pretty much fixable.
Later cabbies are better built and have less rust issues. Plus they are probably a bit safer.
You should be able to find a decent tin top for 7k and you'll have a choice of tip top condition cabbies at that too.
Ian
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/a0baa6c9894dc57b7e44c44f8834c9ed.jpg)
![Fausto in the usergroup ‘Old timer’ Fausto in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
https://www.vwheritage.com/blog/2015/06/12/vw-heritage-buying-guide-mk1-golf-convertible/
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
![chortle in the usergroup ‘Local hero’ chortle in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Bowing of the roof above the side glass is more often than not is the fact the roof has shrunk.
Very common issue. So even if the cable has snapped it won’t cure a shrunken roof.
The insulation padding and interliner are available from myself.
As are replacement rear window frames. In fact Headliners, roofs are available from myself and I can supply and fit.
Most rear window frames are replaced where needed at the time of hood replacement.
One thing to remember is that in the factory the top assembly as it’s known consists of these parts in order when fitted to the bare frame.
Headliner
Interliner
Padding
Outer cover.. aka roof, hood, top.
So when viewing a car if the headliner is dirty beyond cleaning or ripped damaging hanging down.
You will need to remove the outer cover the Interliner and padding to give you access to the fixings of the headliner.
You cannot fit a new headliner with the hood in place.
There are also 3 sizes of headliner not a one size fits all.
A lot of sellers do nothing to the roof and concentrate on paint etc.
So to check rear window frame kneel on back seat looking out the window and locate the rubber seal as it laps over the frame. Lift the seal away and run your finger under and around the frame. If rust flakes come out etc then the frame is likely goosed.
Open the roof halfway and lift the roof away from the middle section.
If you can see the green pad then The capping sheets are shot.
Check the base cloth for deterioration as these often fall apart.
Most pads are beyond their useable life now being around 30 years old.
Expect to pay £1,600 to redo the top from scratch.
That’s headiner, interliner, padding, rear window frame. Cables and labour fitting.
Bear those costs in mind when looking at a car.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Hs05-1.jpg)
![1985 in the usergroup ‘Paid Member’ 1985 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![1985 in the usergroup ‘Old timer’ 1985 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Stormforce seem to do covers that do the bizz pretty well and they honour their warranties pretty well
Waxoyl, decent wax, and wheel sealant are your friends
Current rides:
![IMG_20190803_123357.jpg IMG_20190803_123357.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1567341659/uploads/attachments/5d6bbc56973d7.jpg)
The cabby underwent a facelift in 1988. So the Clipper and Cabby GTI both had the facelift treatment by having the same kit fitted.
Being as they are separate models, different engines a GTI isn’t a Clipper.
So it’s official Monika is “facelift model”.
I’m not sure why or how the whole Clipper kit thing started.. I did hear a motoring magazine during a review back in the day wrote that.
But others call it the big bumper model.
Thanks for the warm welcome
The buyers guide is great - gives even me a little confidence now entering this market
Off to see my first example today
I'll keep you posted
Crowey26
If you buy and need your roof sorting give me a call.
![](https://uploads.tapatalk-cdn.com/20181102/b74cd0a11b7eb8170b210226e17c0412.jpg)
But regardless of what they are called the later models that wear a shell suit are probably better cars with regards to being covered up away from the elements at least arches wise
![](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1620504746.jpg)
Current rides:
Well - been to take a look at my first Cabby.
https://www.londonandsurreycars.co.uk/view-stock/hampton-court-surrey-volkswagen-golf-clipper-956/
I must say a fine example, but at £8k - I have high expectations.
the guide on this site was SUPER helpful and even a total novice like me, is now able to hopefully, dodge a bullet now and keep sellers honest.
Here are my observations:
1. New roof needed. Electices were good but saggy inside, torn outside. Guy knocked £800 off or offered to have done
2. Rusty petrol pipe - now this was a bad issue on my orginal back in the day - and made me nervous
Seller seemed shocked and immediatly ordered a new pipe there and then - seemed genuine but i wonder if there is damage to the engine?
3. a few cracks and new seals needed here and there but overall, it was a real beauty and VERY orginal
4. the drive was great. engine sounded sweet, not tapity', no smoke, picked up lovley and ran cool.
5. steering pulled left a litte - again seller immediatly agreed to fix
6. brakes - oh my, they are poor - BUT its the first car like this ive driven for YEARS and im used to my new BMW 2 series and wife's brand new Sportage - this car had brand new brakes and hadnt been driven
7. gears, crunched twice getting into 2nd - warning lights in my head - but with a new clutch, i ensured I floored it and the crunch dissapeared. Seemed ok
8. bodyword - the paint job was Excellent, minor marks but for age, excellent. the rust in the pic was from under the door sills. not too bad to be fair.
![IMG_2323.jpg IMG_2323.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189886/uploads/attachments/5bdcb0fdd127d.jpg)
![IMG_2324.jpg IMG_2324.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189890/uploads/attachments/5bdcb1019f689.jpg)
![IMG_2325.jpg IMG_2325.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189892/uploads/attachments/5bdcb10427f34.jpg)
![IMG_2327.jpg IMG_2327.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189895/uploads/attachments/5bdcb106b0fa9.jpg)
![IMG_2331.jpg IMG_2331.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189897/uploads/attachments/5bdcb10927055.jpg)
![IMG_2332.jpg IMG_2332.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189900/uploads/attachments/5bdcb10b96d1e.jpg)
![IMG_2333.jpg IMG_2333.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189903/uploads/attachments/5bdcb10eda6a2.jpg)
![IMG_2334.jpg IMG_2334.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189906/uploads/attachments/5bdcb111894fa.jpg)
![IMG_2335.jpg IMG_2335.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1541189908/uploads/attachments/5bdcb113e33d1.jpg)
Take a look at the pics - i'd love to hear your thoughts and thanks for showing such interest.
NB: the following taken from the seller's website: 'With updated CD player and electric roof. In what I would say is an above average condition compared to some of the Clippers still out there. Our workshop has completed a full service, timing belt change, gearbox oil change, clutch replacement, four brand new tyres and MOT safety prep to leave no advisories and keep you as safe as can be. A great overall example, a true classic'
Lets be honest if it was a private sale it would be 6.5k tops to start with.
Its not a bad one by any means, in fact its quite a nice one but its the time of year when cabs can be had for not much money and I think you can find better for less, particularly if you stick to private ads
Current rides:
Cars look ok but roofs rear window frame headliner etc all no good.
Sellers often reluctant to lower prices.
paul_c said
I don't understand where the 8k (or 6.5k) figure came from.
Hi
£8k is the asking price from London and Surrey cars
It seems those much more knowledgeable than me believe car worth circa £6k
This is a garage sell - hence top price
The roof needs doing - seller agreed to £8k sell WITH new roof
chortle said
That’s the issue I’m seeing a lot.
Yap
100% new roof needed
Seller agreed to sell for £7200 with rxksiting roof or for £8k with new roof
![Roach in the usergroup ‘Local hero’ Roach in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
4K maybe.
You could get a lovely tin top for 8k.
I doubt it's going to be snapped up at that price. Most people wouldn't even consider it tbh as, in my opinion, it is massively overpriced.
I'd be a little concerned with the crunch into 2nd as this is usually a sign of the gear bix being a bit fragile and probably on it's way out. The top selector dohickey spring thingy gets worn and then the gearbox ends up jammed in one gear.
At least you have a good starting point to compare others to
Good luck
Ian
