Simple window washer tubing question
(In Topic #217863)
Replacement pipe
Not with the car at the moment but wishing to replace my window washer tubing as it looks brown and terrible does anyone know off the top of their head the inner diameter of the window washer tubing please? I'm guessing 4mm but just wanted to make sure
thank you
1991 Mk1 Golf GTi Rivage 1.8cc
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
I removed the Egg-Crate which eliminated the one hose with 2 large Chrysler check valves hiddened in the rain tray, I moved the washer hose and fed it with the hard nylon hose through the hose frame to make it cleaner and to clear the rain drain.
I used a brass barbed fitting to joint the hose at the firewall seal so it wouldn't get crushed and diminish the flow of fluid.
Here is how it is routed now.
Here is how it looked when I got it home the original
I hated working around those tubes.
But the reservoir end was 5 inner
I bought 4 inner and found this out after I ran the hose as you said bri to the reservoir end 🙈
Just wudnt push on
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
113k on the clock
Owned for 16 years
