Mk1 golf electric windows
(In Topic #217900)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Avatar1504089154.jpg)
![Dazrogers91 in the usergroup ‘Local’ Dazrogers91 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
growing with information.
A1 Cabbie Power Window Problems | VW Vortex - Volkswagen Forum
Page 4 has what the cabbys controller looks like.
The inputs to the thing are 3 connectors that are keyed.
one for each window.
Posting pictures of what you have go a long way to helping us, as I don't have the Corrado's Bentley or Haynes to read the wiring diagrams.
I do know that that switches between the Corrado and the Passat are the same save for the rocker cover is "upside" down for the Cabriolet.
![](https://uploads.tapatalk-cdn.com/20180612/f88b621341764f0a069990059b51270a.heic)
![](https://uploads.tapatalk-cdn.com/20180612/4947e42a3ca705a5c9cdbc5f043b05ac.heic)
![](https://uploads.tapatalk-cdn.com/20180612/9c421c61b49a66ac6e173c72f37177ec.heic)
![](https://uploads.tapatalk-cdn.com/20180612/a0a4cddcd63aafa12d8555402182490f.heic)
![](https://uploads.tapatalk-cdn.com/20180612/29888fe776976e7c4ba6ce6ff83e0a6d.heic)
fusebox side of the loom you shoudl have black and/or black/blue which needs ignition live -> G spade 1, 2,3 or 5. brown/white -> door pin switch for interior light. red wire from fuse -> p spade. red/yellow ignore. fat brown from module find a good earth near by, bare metal a bt of bodywork and self-tapper will work if it wont reach anywhere handy
You will have power to the controller for 15 minutes after you turn the key off.
It was a Trick I found, that I was tired of forgetting to roll my windows up after I had gotten out of the car and closing the door.
So one day when I was diagnosing my windows, I started to look at the wiring, (it was a broken ground/power in the loom between the door and the "a" pillar.
Cutting the brown/white was a blessing….
![](https://emoji.tapatalk-cdn.com/emoji85.png)
![](https://uploads.tapatalk-cdn.com/20180612/83fbe453538ebfa8b50968f7e02bf28a.heic)
![dashlamp-1.JPG dashlamp-1.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1528826026/uploads/attachments/5b2008a84a4bf.jpg)
Fortunately that it is only two wires, and a fish tape helps.
If you don't have electric windows, then you also may have to make a couple of new holes to get them to mount correctly, I even had to cut a larger hole for the window stop.
![door008-1.JPG door008-1.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1528826029/uploads/attachments/5b2008aca6452.jpg)
see the 2 pin plugs with the thick brown/red and black/red, these are the motor power wires. For whatever reason the corrado loom has the window plugs the opposite way round so you have 2 female ends. you need to find a male plug and splice it to the corrado loom, or the mk1 regulator
Before you solder the plugs check the windows work the right way round though, you have a 50/50 chance of getting it right the first time
