Oil problem
(In Topic #217878)
![Damir in the usergroup ‘Regular’ Damir in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Golf mk1cab 2h engine rattle noise
I had problem on my cab for 2 weeks ago, ratlle noise from engine, idle and about 2000 rpm.
Had a oil pan dawn and a rod bearing nr1 dead. Nr2 not as bad as nr1.
A put the new ones and pat the pan back, a drive it in 2 weeks now, and it leaking from oilpan seeling, i tok it off, and i removed bearing nr1. I can see a scrathes again. It has a problem again. A removed a oilpump and there is a scrathes there to.
Sorry for my english. Hope You can help. Thanks on advance
![B7A16D5A-9044-41AB-AA53-4B17F310880D.jpeg B7A16D5A-9044-41AB-AA53-4B17F310880D.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1528568711/uploads/attachments/5b1c1b859be8b.jpg)
![8B60E8A2-0D07-4DBA-9646-90F2977C371D.jpeg 8B60E8A2-0D07-4DBA-9646-90F2977C371D.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1528568715/uploads/attachments/5b1c1b8aa0612.jpg)
![859E25B1-6F21-4B4D-9537-8C37897B8C16.jpeg 859E25B1-6F21-4B4D-9537-8C37897B8C16.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1528568719/uploads/attachments/5b1c1b8ecf610.jpg)
Why opgrading it to 2.0l. Bying new samme pump, is it bad idea?
And yes a use u lube when installing
Over here on this side of the pond the 2.0 pumps are actually cheaper than the 30-32mm 1.8 ones.
And You mension something trust washers, why Them.
Some bearing sets have bearings with built in Thrust washers.
The last set I bought had the bearings with the inbuilt thrust washers.
They prevent in and out movement of the Crank, and are usually on the 3rd con rod.
vwheritage on the Cabriolet engine, shows a picture of the crank bearings with the thrust washers
