Help bringing a GTi back!
(In Topic #217748)
Little power
Sure it will be loud for the test but it is one that had me stumped for a few days on a toyota that I owned once.
Being stateside, I would HIGHLY recommend getting a Bentley service manual for your Mk1.
As for your described troubles… paging Dr. Briano1234
Briano1234 said
Drop the exhaust at the manifold and see if the rpm can increase, as this sounds as if the muffler is collapsed internally.
Fausto said
Welcome! That is a lovely looking GTI you've got.
Sadly no luck, we took the exhaust off today but it didn't help. So another guess I had was the fuel pump again maybe? I order a Bosh one that will come in tomorrow that I'll install after work because maybe the off brand one just isn't doing it? Not really sure. Also ordered a Bentley manual!
I would look at the air plate and see that it is cree to move and not sticking, a car that sits can lacquer up and a restrictive air plate can cause fuel flow issues to the injectors.
Vacuum leaks can cause issues as well, the injectors may need to be cleaned, and the seals replaced to verify that you can spray a cone of fuel.
Duty Cycle is also an issue with the CIS system.
Don't willy-nilly swap out parts, as the fuel pump is at 75 PSI to the fuel Distributor.
below is a good link to mk1 information that you need to look at. The first is based on the Cabriolet, but the engine/suspension/tranny information is the same as the Westy.
The Second link has a wealth of links.
www.cabby-info.com
Tech Groups
Current rides:
Briano1234 said
I would verify that you are statically in time, by aligning all the timing marks.
www.cabby-info.com
Tech Groups
When I get home tonight after work I will make sure all the timing marks are in line and I will also clean the injectors and replace the O-ring surrounding them. I had my buddy use his smoke machine to test it and could't find any holes or cracks. Thank you so much for both of those links as well! I
WATERNAIR said
From personal experience and the exact same symptoms I would say it's a vacuum issue, either a stray pipe somewhere or (bearing in mind the age of these cars) a split or perished hose or line somewhere
I had a good buddy of mine use his smoke machine to look for any leaks and we couldn't find any. I still plan on replacing a lot of the hoses anyways just because of age as well.
- YouTube
1.Yellow "T" piece doesn't looks like proberly sealed. And seems that he is not needed there. (or missing some components, which he connects). Also check connection to brake booster.
2. Pipes from valve cover. One which goes to intake manifold taking uncounted air. Try to disconect it and blind. See what going on.
Smoke test cant show some parts for leaks, it depends where you hooked smoke tester.
Also you should chek ilding screw o ring.
Last edit: by EvilDust
Templates can be found at www.cabby-info.com
Looks like from the picture you are missing the idle stabilization valve, and the vacuum line to it (should be on the Strut tower to the left as you look at it.)
Once of the nipples seems to be missing a cover.
Vacuum leaks are the bane of these critters and a little one no matter how small can cause havoc, bad idle, poor fuel economy, and generally making you pull the hair out of your head.
