1982 lido green resto
(In Topic #217571)
since looking at the pics again I'm wondering…. what mind altering drugs was i on to even think about handing over actual real english pounds for what can only be described as an oversized airfix kit!!!
tbc
Challenges and results like this just underline how a strategic approach to completing one task at a time, rather than being overwhelmed by the enormity of the overall task wins through in the end.
Anyone undertaking a restoration needs to see this before they start.
Now bloody hurry up and finish it!
If i had been the one to strip it it would have been finished a long time ago but I'm finding the images in a haynes manual aren't exactly "high res" simple tasks like setting the timing with no info on which marks to use and connecting wires under the bonnet when there are no references as to where anything goes are little hurdles i need to overcome.
On the plus side i had a couple of hours on it this week so far and managed to build the passenger door including fitting the ridiculously annoying door rubber. and i also got time in my paint booth to blow a couple of bits in.
I'm getting "http error" whilst trying to upload pics so will try again when i get 5
Gave her a bit of a wash off this evening to see how the bodywork has faired over the winter whilst outside under a cover.
Pistol said
Might just be the angle of the photo, but are your brake pipes not running quite low to the ground? Â They look a bit vulnerable.
 Â
They aren't fitted in that pic, they were just hanging after running them down the car.
You missed the nails being used to hold the pads in tho 😉
On the subject of brake calipers and pads, you are also missing the anti rattle clip?
rest assured after the mock up it was assembled correctly
Thanks to Roach who sent me out the last lot of missing parts for the car, bit of a legend
kinda fallen at the first hurdle. According to the manual and all the info i can find online the pipe id the right one for my engine but…. as the you can see from the photo's theres no water inlet on the bottom of the manifold. il have to get a bit of pipe and blank it off as the rest of the pipework is spot on.
Yeah just blank off that outlet I guess, earlier cars had a water fed inlet mani.
Realised both the coil and the horn are the wrong ones, i can work around them for now.with a bit of wiring bodgery until i find the right ones.
The one thing that has me puzzled is the rad fan as it has a direct feed to the battery for both the live and earth (via the thermo switch) and no fuse, im wondering if someone has at some point bypassed a fuse or relay or if its standard.
anyhoo… pics… the year stood outside hasn't done the bare ally surfaces any favours.
