Cabrio flywheel/clutch fitting
(In Topic #216218)
![Chiz_Connor in the usergroup ‘Regular’ Chiz_Connor in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Currently in the process of putting my cabriolet back together after a few modifications. The engine is at present sat in my bedroom 🤣 I am fitting a new clutch and lightened flywheel to the engine while it's indoors.. problem I've got is I first took it apart about 7 months ago and made extensive notes and pictures but failed to note whether there was a gasket between the engine and first plate of the clutch?.. only reason I think there might be is because there seems to be a ridge machined into the engine that looks like it would fit a gasket perfectly? Has anyone done there clutch recently?
Any help would be much appreciated!
1992 Clipper Cab converted to single headlights
Powered by 1.9 TSR Donnington gasflowed engine
4-1 manifold
Stainless steel custom exhaust system.
Now rocking a fresh new mohair roof and respray 🤙🏼
4-1 manifold
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
![greavsy in the usergroup ‘Local’ greavsy in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Which style of engine as in 2h, dx, and what tranny type.
A good place to find out is the ETKA.
http://www.oemepc.com/
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/music.png)
![Woolcott in the usergroup ‘Paid Member’ Woolcott in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Woolcott in the usergroup ‘Newbie’ Woolcott in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
4-1 manifold
4-1 manifold
