Golf Gti Campaign Breaking
Many parts still left
Hi mate do you have any of the side window glass in green tint left
thanks
Happen to have a mk1 mfa speedo/cluster/clock?
I wondered if you had the two exhaust heat shields that should be fitted to the front exhaust downpipe on a Mk1 1.8 GTi
Part numbers 055253701A & 055253701B ???????
Hi, yes I do. Manifold and down pipe still attached to engine thou on car. Where are you located?
I am near Bristol.  Where abouts are you ???
Can I confirm they are the right parts as shown in the diagram below : items 24, 25 and the brackets 32
Tonky
Would you be able to get them off the car at all????
Sorry for late reply, been at Busfest. I am not sure how to be honest. I guess I need to remove the manifold or is it just the Down pipe?
Do you have an auxiliary air valve still?
'83 Diamond Silver Campaign GTI
'85 UR quattro 20v 5 cylinder
It's a 1.8 carb, not sure they have one do they….. sorry I'm on a steep learning curve!
Hi Tonky, no problem. I thought you had a campaign Gti breaking. Thanks for the reply
Hi,
I'm after the inset that goes in the sill at the bottom and the very bottom of the front wing screws into it. It's at the back of the wing.
Chris
Hello,
Do you have 2 complete doors?
Brgds,
Simon
sjeffs said
Hello,
Brgds,
Simon
Hi Simon, yes I do. Windows are electric but I am unsure if they work as it's been sat for a while. Door cards aren't attached and are grey with additional speaker holes cut in them. Any more info needed just ask. Best wishes Callum
chrisL said
Hi,
Chris
Hi Chris, I'm not too sure what you exactly mean as i haven't had to rebuild that part of my car. If you still need the parts, photo would help. Brgrds Callum
Do you still have the brake bar linkage. If so i just need the pivot parts at the ends of the rod with the swivel bearings/bushes in x 2 if possible. Also a couple of the clips and pins :thumbs:
hey i'm after the majority of the rear tub and parts of the floor upto and including the rear beam mounts like in these pics carpet1.JPG images.jpg IMG_7288_zpsa47c0f53.jpg
Hi,
Do you have a half decent Nearside 3Dr Quarter Panel?
James
Jdot9 said
Hi,
James
Hello, I do have a quarter panel but it's still attached to the car. I haven't the knowledge of how to cut one out either - sorry
Hi, where are you based? I need a few small body panel sections, if you're not far away (from Surrey) would you be amenable to me coming over and cutting out what I need? (After agreeing a price first obviously!)
Hi I'm 5 minutes off J16 of the M40 probably 2 hours from you. Depending on what panel bits you need I may be happy for you to cut them out. I really don't want the wings or doors messed with thou.
