The older blokes meccano set
(In Topic #215838)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Screenshot_20180105-123831.jpg)
![Webby! in the usergroup ‘Regular’ Webby! in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
But with Christmas leave commencing I thought what better way of freezing myself than pushing the shell into the garage and starting the long rebuild process. I purchased the shell with a load of parts about 4/5months ago and have spent the interim time researching paint types, bodywork and engines. Now I am totally confused it seemed apt to commence!
so I bought the shell as an unfinished project. Some welding has been carried out on the shell and some new panels replaced - new front wings, new front panel, new rear valance, new fuel tank (obviously the tank isn't a panel, but hey we'll include it on the list!). The car has no engine, or any ancillaries attached. It's is like starting a build from scratch. So what is the plan…
starting with the engine bay. I was going for a smooth bay and follow the usual trend, however recently I have rethought that and am now going for a clean original look albeit with battery and washer bottle relocated inside the car. I will do away with the header tank too. That way if I change my mind in future on engines and originality it's easy to go back.
my approach is to go along 'less is more' going for minimum weight (without getting silly) and fun. It is only a weekend car for me and will be a project to test my skills! I was going to get the shell painted professionally but having failed to get anyone to quote me and being a bit particular I have decided to do everything myself. Not sure how this will turn out but I have painted before and my theory is that by the time I pay to get it done professionally I can mess it up a good 3/4 times myself and still be in pocket and will have developed new skills. Good theory, lets put it to practice…..
So i have started sanding down the engine bay and filling some minor marks etc. I have removed some sealant patches and almost ready to epoxy primer ..
photos to follow
![20171220_120940.jpg 20171220_120940.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514124696/uploads/attachments/5a3fb594cefae.jpg)
![20171220_120936.jpg 20171220_120936.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514124700/uploads/attachments/5a3fb59b0fc3a.jpg)
![20171220_211447.jpg 20171220_211447.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514124704/uploads/attachments/5a3fb59ee0812.jpg)
![20171222_172647_001.jpg 20171222_172647_001.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514125212/uploads/attachments/5a3fb79aa7fd1.jpg)
Then whilst waiting for some filler to dry in the engine bay, i had a look at the inside.
My the theory is: get engine bay and inside prepped, primered and painted. Then I can start reassembling stuff before moving onto the outside. Also I practice prep and paint on the less obvious parts so by the time I get to the outside I will be an expert!
So I had a look at the front pasenger floor pan:
![20171222_201615.jpg 20171222_201615.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514125216/uploads/attachments/5a3fb79f1e3a2.jpg)
And almost finished cleaning up:
![20171222_204724.jpg 20171222_204724.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514125220/uploads/attachments/5a3fb7a3521c6.jpg)
First one - the car came with coilovers fitted but being a bit older and needing comfort over lows I want to get rid of the coilovers and go standard type setup of damper and spring. Am i right in saying people recommend Bilstein shocks with Eibach springs as best comfort and handling? Open to comments / thoughts. I do want to be able to push on in the car, so want something decent, not just std kit.
What is the general thoughts on best lowering distance to improve handling whilst not making the car a bone shaker?
2nd question
Best ARB options? Std spec or larger / smaller. I seem to remember reading a smaller diameter bar at the front is advantageous and stops wheels lifting?
I am going disc rear conversion as it's already 90% done. Can an aftermarket brake bias adjuster be fitted internally to get over the issues with the std one? That's way have adjustability for track days etc.
Am going with Lupo rear calipers as recommended as being less aggressive than mk4 calipers. Lupo are also.alloy calipers rather than the mk4 cast iron anchors! They run a 32mm piston rather than 36/38 of the mk4 option, thus more gentle touch, hopefully avoiding too much rear lockup. With the bias adjuster should be able to rune out lock up issues…
So no mention of engines yet……
Nope….. not yet😎
![stichill99 in the usergroup ‘Regular’ stichill99 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Your 'factory but cleaner' sounds exactly like my plans for Mynx. I think it works rather well personally.
I also did a rear disc conversion but with the mk4 alloy calipers. I did try a bias adjuster but couldn't get the rear brakes to bleed properly and failed the MOT on them. In the end I ditched it with a 'well we'll see what happens' approach. I also removed the brake servo as well though………
I can't get the rears to lock up, even on a wet road. Admittedly I haven't tried whilst in a corner.
Nice work so far
Ian
![20171229_124158.jpg 20171229_124158.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514580334/uploads/attachments/5a46a96c2ce35.jpg)
![20171229_170751.jpg 20171229_170751.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514580338/uploads/attachments/5a46a970d1e26.jpg)
![20171229_170758.jpg 20171229_170758.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514580341/uploads/attachments/5a46a97466522.jpg)
I'll investigate the Eibach option a bit more. Hopefuĺly someone local might have a mk1 with this setup so i can see what it's like….
![20171230_204021.jpg 20171230_204021.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514672752/uploads/attachments/5a48126cd14da.jpg)
Better:
![20171230_212122.jpg 20171230_212122.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514672756/uploads/attachments/5a4812732fed1.jpg)
![Simon_p in the usergroup ‘Regular’ Simon_p in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![20180102_093118.jpg 20180102_093118.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514905678/uploads/attachments/5a4ba04c7288b.jpg)
Swapping the servo for a larger 9" from mk2 16v. Mastercylinder will be replaced with new 22mm, again from 16v mk2. Was going to do away with servo but general consensus is that is a bad idea due to poor feel on the road.
![20180102_095509.jpg 20180102_095509.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514905682/uploads/attachments/5a4ba051629a6.jpg)
Sanded down and primered the servo:
![20180102_115744.jpg 20180102_115744.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514905686/uploads/attachments/5a4ba0554cb25.jpg)
Now the issue. The brake bar has swivel bearings on the ends - one is shot. Anyone converted their car to non servo and got a spare bar connector like this, but with good bearing?
![20180102_145428.jpg 20180102_145428.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514905690/uploads/attachments/5a4ba058bc657.jpg)
Servo part number: 172 612 105 M
![20180102_115948.jpg 20180102_115948.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1514906204/uploads/attachments/5a4ba25a0d357.jpg)
![20180103_165550.jpg 20180103_165550.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515005088/uploads/attachments/5a4d249e340c3.jpg)
And after a further clean up of the drivers footwell, a bit of primer on that too:
![20180103_165507.jpg 20180103_165507.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515005092/uploads/attachments/5a4d24a332b7e.jpg)
Just got to keep this momentum going…
![20180103_184726.jpg 20180103_184726.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515005327/uploads/attachments/5a4d258df421b.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1566241009986.jpg)
![DANBOY in the usergroup ‘Local’ DANBOY in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
DANBOY.
Mk1 Golf cabrio "Golf+ absolutely cabulous"
fresh 20vt rebuild well underway
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-old-white-cabby#post_1402754
![](https://vwgolfmk1.org.uk/data/external_url_proxy.php?url=http%3A%2F%2Fi274.photobucket.com%2Falbums%2Fjj249%2Fcabrio16v%2Fsigs%2Fsiggy.jpg)
![20180104_200727.jpg 20180104_200727.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515101331/uploads/attachments/5a4e9c8f68260.jpg)
To this:
![20180104_210442.jpg 20180104_210442.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515101335/uploads/attachments/5a4e9c95974bf.jpg)
Need a rest from sanding so i'll get the brake bar components back together before I forget how it all came apart!🤣 I also need to sort out servo amendments to fit the 16v servo clevis pin.
Lot of work to do. Glad I haven't written a job list, I think I'd give up!🤣
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/6J7A7209-30.jpg)
![scottyr1 in the usergroup ‘Paid Member’ scottyr1 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![scottyr1 in the usergroup ‘Old timer’ scottyr1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Webby! said
2 hours of scraping and sanding and we go from:
To this:
Nice work 👍
![20180105_122447.jpg 20180105_122447.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515155637/uploads/attachments/5a4f70b3de72a.jpg)
The previous owner had just blown over everything with matt black to make it look better/further progressed than it was. Albeit no structural corrosion found so far…
![20180106_120352.jpg 20180106_120352.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515258287/uploads/attachments/5a5101ac18f9e.jpg)
Welded it up:
![20180106_122319.jpg 20180106_122319.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515258292/uploads/attachments/5a5101b287fdd.jpg)
Cleaned up last footwell:
![20180106_154927.jpg 20180106_154927.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515258296/uploads/attachments/5a5101b689474.jpg)
![20180106_165230.jpg 20180106_165230.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1515258300/uploads/attachments/5a5101bb62e88.jpg)
