no spark gggrrrrrrrr
(In Topic #215635)
![Worz8 in the usergroup ‘Local’ Worz8 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
i got no spark ive changed everything!! module, ignition coil leads, theres power going into all the above but just not producing a sparkfrom the coil?? its just one thing after another ive fixed the vaious fuel leaks i found once powering the fuel pump, again which i think ive done incorrectly as when i take the relay out its still works off the ignition?? i followed the fuel pump topic on the forum but not sure if i done it right!
im sure i will get there but all the help will be muchly appreciated ive enclosed some pic of what ive got and done pleeeeeeease help before i push it into a river
Electronic, on the side of the dizzy there is a connector.
carefully separate the rubber boot off the plug.
with a DVOM 20V scale
There should be a positve, a negative and a white and green signal wire. Place your meter on the signal wire, and the other side to ground.
Key on Slightly rotate the dizzy, you should see the meter go from 0 to 11V and the fuel pump should run.
Back it off and re-do it.
That verifies your Hall Sender, so suspect the ICM or the coil.
points, then adjust them and replace the condenser
OH Timing set the timing statically..
![wilko13 in the usergroup ‘Paid Member’ wilko13 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![wilko13 in the usergroup ‘Old timer’ wilko13 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Thanks again for all the help
With no fuel pump relay installed and you turn the key, then there shouldn't be any fuel pump activity…
Grounds Grounds Grounds,
Can't pound on that enough…….
Battery to frame, frame to engine/tranny.
Head (valve cover) to bracket on coil.
Shoot, there shouldn't be any emissions crappage that will prevent spark.
I would start resistance or voltage drops between the engine and the battery, then the frame to battery, Should be basically the same as between battery posts, over a .5V difference then you have issues on your cables usually groundy ones.
Also measure the difference between the Coil Bracket and frame to the Positive Post (voltage)….
can somebody please just tell me the wiring configuration just so im on the right page please
i have 2 black wires
one green wire
and 1 black and red wire
thanks in advance
![](https://uploads.tapatalk-cdn.com/20171206/8a3df84d35bb65f57b4c15e27147b0a9.jpg)
Red is on same twin block as the green.
Dizzy
![](https://uploads.tapatalk-cdn.com/20171206/d27c061a8421cf4d13ff2da6a8996620.jpg)
Hope this helps
thanks again
I've done all the grounds
I now have changed the coil twice
I also changed the icm then got another spark
But then nothing ?
Does the icm need to be earthed?
Or is there anything wiring wise that could be blowing the icm up or the coil each time ?
Thanks again
![](https://uploads.tapatalk-cdn.com/20171207/ed43524bc1cdbb381d1520534f9325f3.jpg)
