1990 mk1 Golf Clipper Cabriolet, breaking
(In Topic #158608)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/chess.png)
![esSEXY in the usergroup ‘Regular’ esSEXY in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The project was meant to be an overall refresh and engine transplant, as the car was solid but somewhat unreliable. Here’s the car in its ‘prime’
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/Golf1_zps18f3a339.jpg)
For all but the smallest of items priority will be given to anyone willing to collect parts. I have tried to group similar items together, but please ask if there is anything specific you are looking for.
Body
1990 mk1 golf cabriolet shell. VIN and V5 available; new genuine VW front panel recently fitted (as it was deemed to be easier than fixing numerous small dents and ripples), very solid in all the usual problem areas, but the engine bay was in the process of being smoothed. The following parts are currently fitted, but could be sold separately if there is enough demand.
Electric power roof
Doors
Boot hatch
Glass
£75
Clipper kit and front wings. Complete but would benefit from a respray, the only notable damage is to the rear inner arch plastic liner which was cut where it should join to the side skirts, see picture, I suppose it could be repaired but it always functioned and looked fine when fitted to the car. Should have all clips etc. £40 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2822_zpsabe80f7b.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2826_zpsb9600915.jpg)
Bumper bars. Professionally powder coated in black with slight metallic finish. £25 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2801_zpsdb560ff1.jpg)
Engine Bay
20VT engine and gearbox mounts, brought from VWCaddy.com, sold as set including the original front and rear mounts. Professionally powder coated in black with slight metallic finish. Comes with new genuine VW rubber inserts and bug pack poly bushes. £100 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2767_zpsf3d2efbd.jpg)
Big block engine mount and 5 speed gearbox mount. Original big block engine mount and 5 speed gearbox mount with original inserts in good condition. £20
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2821_zps48dffcb2.jpg)
Weber carb. Comes mounted on inlet manifold, was tuned after it was installed and gave great performance and economy, I also have a cold air manifold, not pictured, it’s not the prettiest part but functions very well. £50
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2794_zps2722c6c6.jpg)
Wheels
Space saver spare wheel, plenty of tread on tyre. £10
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2828_zpsef55a19a.jpg)
BBS RJ wheels. 4x100 6.5jx15 ET33 with centre caps. I believe these originally came off a Corrado G60. Fitted with 195/50/15 Falken ZE512 tyres with plenty of life left on all of them. £150 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2817_zps67aee64a.jpg)
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2816_zps77752f20.jpg)
Brakes/Suspension/Steering
Vauxhall front brake calipers with 256mm Brembo disks, plenty of life left in the pads and disks, but would need a skim to remove surface rust. Comes with original Vauxhall hoses and custom stainless steel tophat bushes to allow direct installation. £30 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2793_zps73a157a2.jpg)
Rear beam. Professionally powder coated in black with slight metallic top coat, modified to use ‘P’ clips to secure brake lines. Bug Pack poly bushes included and installed. £50 SOLD
Mk2 golf rear disk conversion stub axles, disks and calipers (brought as reconditioned items shortly before the car was taken off the road). The pads and disks where performance items, but can’t recall what brand. £30 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2778_zpsf81b6acb.jpg)
Original front uprights for 100mm driveshafts including hubs. Will require new wheel bearings. £50
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2788_zps7412bb91.jpg)
100mm drive shafts. Professionally powder coated in black with slight metallic top coat, will supply with original CV joints which have been cleaned and re-greased, but the boots have been misplaced. £50
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2789_zps26976c65.jpg)
Front ARB, includes all mounting brackets and BugPack poly bushes for control arm. £25 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2782_zps032a957a.jpg)
Rear ARB, includes mounting brackets and BugPack poly bushes for stock ARB, but will require new clamp and outer bushes £25 SOLD
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2785_zpsa8bd912e.jpg)
Steering rack. The housing was smoothed by removing the gearbox linkage mounts, perfect if converting to 02J gearbox, then cleaned and painted, before being rebuilt with 2 adjustable Lemforder track rods, new track rod ends and new genuine VW boots. Supplied with mounting brackets and BugPack poly bushes. £25
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2769_zps78644302.jpg)
Steering column and pedal box. £10
Misc
Wiper linkage and arms. The linkage has been stripped, cleaned and re-greased. The wiper motor was changed to a modern Polo item which greatly increased the ability to keep the screen clear. The arms are in good condition, but the finish has started to peel. £10
![](https://vwgolfmk1.org.uk/uploads/pbextract/1314650/IMG_2774_zpsf5655f33.jpg)
Fuel tank with lift pump and sender £10
Rotisserie £20
Badgeless grill £10
Rear lights £10
Last edit: by esSEXY
![project1 in the usergroup ‘Regional Hosts’ project1 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![project1 in the usergroup ‘Old timer’ project1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
dave
![](https://i1097.photobucket.com/albums/g354/projectmk1/1320188386.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/237image.jpg)
![Talizman in the usergroup ‘Local’ Talizman in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Dessie66 in the usergroup ‘Local’ Dessie66 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
des
I have both smoke crosshair headlights, but one is cracked so I assumed they are worthless. I have most of the seals still fitted on the shell so I guess I would have them
The fuel tank was sent away to be professionally treated but came back with some internal coating that has locked the filler flap when it set. You might be able to have the coating stripped as the insides look very clean under the coating. If your still interested let me know.
Colin
Guest user
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/aaaa.jpg)
![arf333 in the usergroup ‘Regional Hosts’ arf333 in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![arf333 in the usergroup ‘Old timer’ arf333 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Guest user
Dessie66 said
Petrol Tank and Sender please. Where are you actually based?
des
![Reddood in the usergroup ‘Regular’ Reddood in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![guybagnall in the usergroup ‘Local’ guybagnall in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sorry I dont have any interior parts left here.
Cabfan:
I've sent you a txt.
![Jbvw in the usergroup ‘Regular’ Jbvw in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![suffolkmat in the usergroup ‘Local’ suffolkmat in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Still have the driveshafts, PM inbound.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/19image.jpeg)
![Laracb in the usergroup ‘Paid Member’ Laracb in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Laracb in the usergroup ‘Local’ Laracb in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/65650_142112045976868_1056358099_n.jpg)
![Cabby77 in the usergroup ‘Regular’ Cabby77 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![SEAN1151 in the usergroup ‘Old timer’ SEAN1151 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Many thanks Sean
CAMPAIGN-HELIOS BLUE-POSSIBLY SEEN IT ON CHRIS BARRIES(RIMMER IN RED DWARF) MASSIVE SPEED PROGRAMME?!!!
