Spark then no spark?
(In Topic #215278)
![williamtwhyte in the usergroup ‘Regular’ williamtwhyte in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Getting 2 or 3 sparks then nothing until I turn of the key and back on
I have the plug out for testing, when I crank the car I get two or three sparks then nothing after that,
If I turn off the ignition and turn it back on I get the same again two or three sparks then nothing
Any help would be greatly appreciated
William T Whyte
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
![vwoldmad1 in the usergroup ‘Local’ vwoldmad1 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
is the dizzy cap ok and rotar arm
is it the same on all 4 plugs
just a few things I can think of
no expert though
I ordered a new TCI also
William T Whyte
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
'74 Beetle
'82 Mk1 Golf
'08 Mk5 Golf
![gameed in the usergroup ‘Newbie’ gameed in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
If more than 12 months old I would replace them 1st to see if that helps…
Have some one cycle the ignition switch and while they do that you get under the shrouded bonnet and look for
Sparking Fairies dancing about your HV leads. If you see them, then use sand paper to buff the area, and continue. Common ares on these that I have found are the metal jackets to the block.
