Mellow Yellow 3.2ltr 24v Conversion
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/7avatar.jpg)
![Rich. in the usergroup ‘Paid Member’ Rich. in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Rich. in the usergroup ‘Old timer’ Rich. in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![gallery_23668_521_34941.jpg gallery_23668_521_34941.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052269/uploads/attachments/5c085e2cdeeca.jpg)
![gallery_23668_521_104720.jpg gallery_23668_521_104720.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052271/uploads/attachments/5c085e2ea6d68.jpg)
Last edit: by Rich.
Busy sorting out my mini last weekend. I recently bought a cooper s for the school commute, its first generation with 50k on the clock. I wasn't sure about a sound I could hear so wanted to give it a good inspection, changed the supercharger oil, water pump and pulleys / drive belt.
Boy this is a tight engine to work on. Nice its a modular design though
![gallery_23668_521_694040.jpg gallery_23668_521_694040.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052557/uploads/attachments/5c085f4c8f54c.jpg)
Bumper off, impact bar and supercharger
![gallery_23668_521_868955.jpg gallery_23668_521_868955.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052604/uploads/attachments/5c085f7b74121.jpg)
This is what i was left with
![gallery_23668_521_1143750.jpg gallery_23668_521_1143750.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052669/uploads/attachments/5c085fbc6848e.jpg)
The idler pulley and tensioner were ok and water pump. Had new ones to go in.
In the end found the culprit, it was the power steering pump fan.
![gallery_23668_521_381802.jpg gallery_23668_521_381802.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052751/uploads/attachments/5c08600ec3937.jpg)
![gallery_23668_521_722089.jpg gallery_23668_521_722089.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052753/uploads/attachments/5c086010c21bc.jpg)
The bearing in the spal fan was super stiff. No wonder it sounded like a cement mixer ha ha
Its in a position under the engine which gets filthy
Last edit: by Rich.
- Remaining engine mounts (Front and back)
- install driveshaft flanges
- fill gearbox with oil
- Driveshafts
- Gear shifter and cables
- alternator
- water pump tighten
- install tensioner bracket for drive belt
- install drive belt
- crack pipe and aux pump
- radiator and thermostat housing
- install headers and downpipe
- install exhaust
- Steering column and pedal box
- Add sensors to block
- tighten 5th gear retaining bolt (selector rod)
Then things left:
- paint inlet manifold
- vacuum lines from inlet manifold to remote servo
- brake lines to pedals and servo (drill holes for pipes through bulk head)
- fuel line (stainless supply line)
- fuel filter (install at rear)
- brake reinforcement bracket (fabricate)
- Main wiring looms (route and create holes)
- rev counter (wiring from alternator to Dakota to dash)
- install dash and dials
- Add engine oil
- water gauge (wiring to dash)
- oil pressure (wiring to dash)
- fan control loom (wiring to fuse box)
- wiring for lights and indicators
- Hydraulic clutch
- install brake calipers
- install brake servo
- battery installation in boot
- Add earth points and cables
- install throttle pedal
- install heater
- fuse box
- wheel alignment
- fab joining exhaust section
- install wings
- polish paint and blend edges
- install front grille
- install bumpers
- install lower trim
- install wings
- install washer bottle in boot
![gallery_23668_521_592154.jpg gallery_23668_521_592154.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052945/uploads/attachments/5c0860d09baf9.jpg)
![gallery_23668_521_892591.jpg gallery_23668_521_892591.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052947/uploads/attachments/5c0860d290eb7.jpg)
![gallery_23668_521_1058520.jpg gallery_23668_521_1058520.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052949/uploads/attachments/5c0860d459bee.jpg)
![gallery_23668_521_1632452.jpg gallery_23668_521_1632452.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544052950/uploads/attachments/5c0860d63f700.jpg)
Last edit: by Rich.
![gallery_23668_521_261457.jpg gallery_23668_521_261457.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053031/uploads/attachments/5c086126b9624.jpg)
Then a dip in Bilt Hamber Deox C
![gallery_23668_521_1221665.jpg gallery_23668_521_1221665.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053077/uploads/attachments/5c086154c6c98.jpg)
Then acid etch primer, high build and flat, grey primer and satin black like stock
![gallery_23668_521_61769.jpg gallery_23668_521_61769.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053207/uploads/attachments/5c0861d6b1170.jpg)
![gallery_23668_521_445251.jpg gallery_23668_521_445251.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053209/uploads/attachments/5c0861d8c8048.jpg)
![gallery_23668_521_503583.jpg gallery_23668_521_503583.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053211/uploads/attachments/5c0861dace664.jpg)
![gallery_23668_521_606630.jpg gallery_23668_521_606630.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053213/uploads/attachments/5c0861dd41bbf.jpg)
Last edit: by Rich.
![gallery_23668_521_347087.jpg gallery_23668_521_347087.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053310/uploads/attachments/5c08623d83dc3.jpg)
![gallery_23668_521_770823.jpg gallery_23668_521_770823.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053311/uploads/attachments/5c08623f7fd03.jpg)
But tomorrow I should have a big update and lots of jobs ticked off the list
Last edit: by Rich.
The front and back engine mounts were a bit tricky to align, the engine was up and down like a yo yo as discovered the bolts used for the transmission mount couldn't position with the side mounts in place. All sorted and aligned now
Attached the driveshafts and steering column
![gallery_23668_521_46755.jpg gallery_23668_521_46755.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053482/uploads/attachments/5c0862e847666.jpg)
![gallery_23668_521_66207.jpg gallery_23668_521_66207.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053484/uploads/attachments/5c0862ebdfa56.jpg)
![gallery_23668_521_88421.jpg gallery_23668_521_88421.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053486/uploads/attachments/5c0862ede32d5.jpg)
![gallery_23668_521_179533.jpg gallery_23668_521_179533.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053488/uploads/attachments/5c0862efed0c3.jpg)
Last edit: by Rich.
![beechey in the usergroup ‘Newbie’ beechey in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![Lhasa2008 in the usergroup ‘Paid Member’ Lhasa2008 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Lhasa2008 in the usergroup ‘Old timer’ Lhasa2008 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I really enjoy reading the updates and with such great pictures! So nice to see home builds.
Lhasa2008 said
Not sure if I have mentioned before, but this is a great thread. Really, really nice to see progress and the time and effect going into this.
Cheers chap really appreciate the comments, I'll keep the content coming. More at the weekend
Hopefully it will end up more store bought than home brew ha ha
beechey said
im in love
Thanks fella. She is coming along now. Bit naked at the mo. Lots to bolt on!
![madone_si in the usergroup ‘Old timer’ madone_si in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_1298.jpg)
![Baggins in the usergroup ‘Paid Member’ Baggins in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Baggins in the usergroup ‘Local’ Baggins in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![gallery_23668_521_98677.jpg gallery_23668_521_98677.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053628/uploads/attachments/5c08637c18e25.jpg)
![gallery_23668_521_99637.jpg gallery_23668_521_99637.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053630/uploads/attachments/5c08637e4f9bf.jpg)
![gallery_23668_521_224096.jpg gallery_23668_521_224096.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053632/uploads/attachments/5c0863805c28e.jpg)
![gallery_23668_521_445965.jpg gallery_23668_521_445965.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1544053634/uploads/attachments/5c08638243a4c.jpg)
Last edit: by Rich.
![madmatt in the usergroup ‘Local’ madmatt in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Love the car it's going to sound and look great!!!
madmatt said
Great work on this Rich!!!
Cheers Matt
Decided to move house so spent several weekends doing up and clearing out the clutter in the house.
The poor garage has taken the brunt and slowly filling up :O
I have a property in mind which unfortunately doesn't have a double garage but has massive potential to create a custom one
So the Golf is on hold for a while, I will try to sneak in some updates in the next few weeks. I can fit the exhaust and shifter which will mean less things to transport to new place
