MK1 Golf GTI 1.6 front engine mount
(In Topic #213717)
Missing front engine mount on my 1.6 GTI
Any one know where i could get one? are they different to the small block MK1's mounts as i may be able to get hold of one of those.
Cheers,
Lewis
1981 MK1 GTI 1.6
You need one like this I believe.
https://www.ebay.co.uk/itm/391693300735
Raul said
Think small blocks are different.
Thank you mate!
1981 MK1 GTI 1.6
18,21 and 15 in this picture for uk cars.
https://volkswagen.7zap.com/en/rdw/golf/go/1980-27/1/199-40000/
mark1gls said
The link above shows the mount which fits to the engine, there is also a rubber bush which fits on the end then there is a bracket which fits onto the front of the car. Are you missing everything or just the mount on the engine?.
Yeah i have ordered the rubber mount and the bracket on the front of the car is still there thankfully. Order the front mount from the ebay link above. Just need to see if the bolts are missing now too. If they are anyone know where could get them?
Cheers for the info and that link mate!
1981 MK1 GTI 1.6
Like these.
http://www.justkampers.com/n01-025-414-vertical-front-axle-bolt-for-vw-beetle-m10x25mm.html
22 N 0403331 hexagon bolt M12X88 x1
23 N 0120424 spring ring 12 x 1
24 N 0110304 hexagon nut M12 x 1
25 N 01047211 hexagon bolt M10X85 x1
26 N 0120113 spring ring 10 x1
27 N 10155207 hexagon nut M10 x1
I have pulled the small block from my car and most likely have these nuts & bolts laying around. Would need to check in the garage, but can post them to you if it would make it easier to find?
https://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=26%2F3%2F4%2F126
So looking at diagram, it shows two engine mounts '18' and '19'. The engine mount i need is '18'
so i think i may need bolt '20' for this?
Which would be M10x135?
http://www.ebay.co.uk/itm/MK2-GOLF-Bolt-Allen-Key-Head-M10x135-Engine-Mount-N0447601-/181529942121
May be completely wrong.
1981 MK1 GTI 1.6
bucket said
If you after 22-27 on the diagram you quoted, you would need. If you buy these don't go to VW, just ebay the sizes (not to tell you how to or anything )
Yeah if you wouldn't mind having a look mate, that would be handy.
1981 MK1 GTI 1.6
