Front brake upgrade
(In Topic #213653)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/Image1504641862510.jpg)
![roblewis in the usergroup ‘Newbie’ roblewis in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
![](https://uploads.tapatalk-cdn.com/20170905/3f4f1c4b6cae1d34edbcbec841c5580c.jpg)
![](https://uploads.tapatalk-cdn.com/20170905/5fe45266de1609e4ebef4f3b821c1a9e.jpg)
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Great photo! 👍🏼
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
Re:
thanks mate. it's my nephew he won't stay away from it when he's over. knows a proper car when he sees oneGolf Cabrio said
Welcome to the club first of all but I you sure you're old enough and tall enough to drive?![]()
Great photo!![]()
Sent from my Smartphone 📱
![abfmk1 in the usergroup ‘Local hero’ abfmk1 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re:
thank you will have another look into it all later I got 15 inch ronal turbo wheels on it so space ain't a hassle just finding the right parts and what is neededabfmk1 said
Cheapest / easiest is probably fitting g60 280 mm discs and brackets to move standard caliper out, makes a small difference. Then same discs but g60 calipers (can be expensive) and adaptor brackets. Theres a conversion using Vauxhall parts , also mk2 golf 256mm (I think) discs, but caliper carriers hard to find. Some conversions require 14 inch and some 15 inch wheels. Also larger calipers require a larger m/cylinder, all the info is on here somewhere I'm sure.
Re:
awesome thanksGolf Cabrio said
I can't help with the brakes but we have many members who can provide sound advice on that subject as well as anything else about a Mk1!![]()
Sent from my Smartphone![]()
![sporttrucker in the usergroup ‘Old timer’ sporttrucker in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
where in cornwall are you? I am down in penzance
Re:
I knowing got the mk2 servo will have a look in to the master cylinder later. thank you. I'm in padstow matesporttrucker said
looks like you already have a mk2 servo and master cylinder on it. would be a good idea to see what size master cylinder you have as some are 20mm and others 22mm. you can also fit the t4 25mm master cylinder I found this with decent discs and pads the standard callipers stop ok.
![bucket in the usergroup ‘Local’ bucket in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Just cannot remember the model year of polo, want to say mk3, but would like to be corrected.
As a side note a thread of interest for you:
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=running-gear_2%2Fwhat-brake-conversion_2
Re:
hi just seen this. thank you will have a look into that my brake upgrade come to a sudden holt as my clutch blow out on me on Friday evening new clutch tomorrow and should have it all fitted by tomorrow night then start getting the brakes done. Will look into this thank youbucket said
just as it is something to look up, the polo 256mm callipers and discs bolt right up, I cannot find the thread at the moment, but I have them on mine. Nice little additional change. Again mine is bolted up to the 16v servo.
