Mk1 Servo change. Brake pipework question...
(In Topic #166298)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20130609_165358_zps201774ba.jpg)
![AndyParsons in the usergroup ‘Local’ AndyParsons in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
My cabby is an 1800 on a K plate and 1993 reg. The current master cylinder has four outlets. Am I right in thinking that the two out the side go to the front brakes (one goes to each side of the car) and the two out the bottom go to the rear? I read somewhere that the cylinders are anti-lock compensators??
![](https://vwgolfmk1.org.uk/uploads/pbextract/1356897/IMG_20131107_101408_945_zpsc67ca2a6.jpg)
So, the replacement master cylinder has two working outlets as shown here…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1356897/IMG_20131107_101444_581_zps36c5ba75.jpg)
But the replacement one has two blocked up as shown here…
![](https://vwgolfmk1.org.uk/uploads/pbextract/1356897/IMG_20131107_101452_962_zpsf0507a12.jpg)
So, when I fit the new cylinder what is the correct method of plumbing in the new system. Is it as straightforward as running the two fronts to one side, and the two rears to the other? As the brakes are a fairly important I'd like to get it right!!!
I picked up this from the forum's Brake Upgrade section...
Now, there's a few variations on the 16V master cylinders you can refit. Essentially it comes down to '2 outlet' or '4 outlet'. Also if you're doing a 16V conversion, you can use the 4 outlet master cylinder but use blanking plugs, so there are 2 outlets on the left (the 2 outlet 16V master cylinder has pipe connections on the right). Bearing in mind the original master cylinder has 4 or 5 outlets (there are 1 or 2 hydraulic brake light switches and possibly a T piece underneath the cylinder) you may need to use extra T-pieces to provide all the connections. For each T piece you introduce, you'll also need a short solid brake pipe (say, 4 inches long) with 2x male fittings (they are a standard, M10x1). It should be possible to bend the existing pipes to reach the new master cylinder (or T pieces). Remember that the braking on a Mk1 Golf is diagonally split, ie the front section of the master cylinder supplies diagonally opposite front and rear wheels; the rear section the others. However you work out the piping, you need to retain this for safety.
you need to plumb diagonally opposite corners into each circuit, basically how it is now just the 2 bottom pipes will go on the side instead
or if its easier for you you could just use 2 on 1 side of the MC with MK2/3 T pieces joining up to the rear 2 lines that used to go on the bottom
![Beema Geeza in the usergroup ‘Paid Member’ Beema Geeza in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Beema Geeza in the usergroup ‘Regular’ Beema Geeza in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Ive just recently purchased my old 91 clipper back after 15 years so I'm in the middle of trying to put it back to some sort of normality!!
it seems to have had the 16v upgrade on the servo and master cylinder.
as you can see it has a 4 outlet with 2 brass T pieces and the two left outlets are linked together.
is it possible to just connect the 4 to all the outlets? as it looks a bit of a mess and I want it to look nice and tidy under the bonnet. As I wrote earlier I'm trying to undo 15 years of bodging and peoples extras.
currently have removed the engine for rebuild and fit power steering.
![image1.PNG image1.PNG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1487629623/uploads/attachments/58ab6d35b913e.png)
Last edit: by Beema Geeza
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
I want to find info about connecting without using the T pieces.
I just think it looks a mess. all I was going to do anyway was neaten it all up but just wondered if I can get rid of them anyway.
Neil
then either plumb the wheels to all 4 holes as you say, or blank off the 2 spare holes. Bleed nipples fit nicely
I've actually got the engine out for rebuild, power steering fit and also having the engine bay painted so I've been concentrating on that for the last couple of months.
I'm going to just fit complete new brake lines anyway so it's neat and tidy. I'll get them to where they have to be then my dad will flare the ends and connect them.
Neil
![IMG_0016.JPG IMG_0016.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794754/uploads/attachments/59a2163e877fc.jpg)
![IMG_0017.JPG IMG_0017.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794756/uploads/attachments/59a21643a25e4.jpg)
![IMG_2369.JPG IMG_2369.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794759/uploads/attachments/59a21646981dc.jpg)
![IMG_2371.JPG IMG_2371.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794762/uploads/attachments/59a21649a004d.jpg)
![IMG_2372.JPG IMG_2372.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794765/uploads/attachments/59a2164c15f82.jpg)
![image.jpg image.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794768/uploads/attachments/59a2164f5c323.jpg)
![IMG_2386.JPG IMG_2386.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794776/uploads/attachments/59a21656e3902.jpg)
![IMG_0335.PNG IMG_0335.PNG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794778/uploads/attachments/59a21659a167b.png)
![IMG_0336.PNG IMG_0336.PNG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794783/uploads/attachments/59a2165e6a585.png)
![IMG_0337.PNG IMG_0337.PNG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794790/uploads/attachments/59a21665d2daf.png)
![IMG_0338.PNG IMG_0338.PNG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1503794799/uploads/attachments/59a2166e8478f.png)
You can just stick the plate on as it come with double sided tape or even paint it to match your very clean engine bay.
http://www.ebay.co.uk/itm/MK1-GOLF-Bulkhead-repair-patch-for-Clutch-Cable-MK1-Golf-Jetta-Sciro-/182627116609?hash=item2a856ca641:g:UsQAAMXQVT9S38nh
mu 83 mk1 cab was still perfect around the hole and with a new sachs clutch gave me no issues
![Amar Vee in the usergroup ‘Newbie’ Amar Vee in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Can i just union join the existing brake lines to my new brakelines i will be fitting please ?
(i will use one port of the MC for each brake)
also any use of compensators needed? i didnt think i would as my 4 port MC can feed each brake in diag.
thanks
Website Manager
The rear brakes must be restricted, either the restrictor that sits on the rear axle or the inline ones that fit on to the master cylinder. You do not want the rear brakes locking before the front as that will spin the car.
Its standard 1.6 GTI 81.. i dont want to put in T pieces if i dont have to ..
edit:I see they are inline regulators so dont need T . Just need to confirm if present already and dont need to installl.
Thanks again
Last edit: by Amar Vee
Website Manager
If it is a GTI then it should have the rear brake compensator connected to the rear axle with a spring.
If you have a four port master cylinder then just plumb each line in to it. When I have done this is the past I bough a reel of copper/nickel brake pipe, some ends and a flaring tool and made all new brake lines. Also added braided hoses. But if your lines are good you can carefully bend them to the new master cylinder. I just wanted new corrosion proof lines.
appreciate your advice mate. Will ping you back here if I get into difficulty. Not lookng forward to taking the old servo out as a fiddly job apparantly .
cheers!
Plan is to do them all independently using unions to the respective 4 brake lines to the wheels.
