Spare wheel well panel
(In Topic #212510)
![Colley27 in the usergroup ‘Local’ Colley27 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Cabbies in mid 84 went from the full sized spare that the early mk1 Golfs enjoyed, to a space saver spare, and a larger gas tank.
![IMG_3342.JPG IMG_3342.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1501111066/uploads/attachments/59792317e09b6.jpg)
![IMG_3343.JPG IMG_3343.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1501111068/uploads/attachments/5979231c5201e.jpg)
![IMG_3345.JPG IMG_3345.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1501111070/uploads/attachments/5979231e015ec.jpg)
You can't really see much by these pictures to be honest but like I say it's around 3-5mm all the way round stopping it from dropping in and there's only a small lip that it welds to as it is without grinding that away.
Backinblack said
I wonder if it was designed to go over the old one from underneath? If you have the time take a cutter to it and separate the base lip and side. Then rebuild it with a smaller diameter. Cut the upper lip into 4 quarters and then reattach to match the new diameter. A lot of messing about though for a part that should fit.
Yeh that's the point I bought the new panel to kind of save time messing around and it should fit really I know that spurious parts aren't the best but still for that price you kind of want it to actually be able to sit in somewhere near 😂
![BirchyB0y in the usergroup ‘Local’ BirchyB0y in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
It looks to be a replacement panel.
![IMG_3355.JPG IMG_3355.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1501188992/uploads/attachments/597a537c79214.jpg)
Where the panel steps out at the bottom of the panel is the problem, I've drilled the outside welds and ratchet strapped it to try pulling it in but no joy so next time I get chance I'm just going to hammer and dolly the sides flat and that should do it hopefully.
![7583AF60-EDAC-4B45-8451-5CC467010658.jpeg 7583AF60-EDAC-4B45-8451-5CC467010658.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1518976351/uploads/attachments/5a89bd5aec2ca.jpg)
![B42DC2B6-FA6D-4009-AD48-CB22BA8F5A5D.jpeg B42DC2B6-FA6D-4009-AD48-CB22BA8F5A5D.jpeg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1518976354/uploads/attachments/5a89bd6154e05.jpg)
I know the panel isn't the same as the original as it has an egg shape in the centre rather than a circle pressing but the original panel has the big holes with the bonded in pieces to the front and back. I can't decide whether to keep it the same as the oval will sit side ways or have the holes to the sides and have the oval facing forward. A bit anal I know but obviously once she's in she's in! Haha
![djholland_ in the usergroup ‘Newbie’ djholland_ in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Colley27 said
Reviving an old post as I'm after people opinions before I weld this spare wheel well into place.
How exactly did you get the replacement spare wheel well to fit. I'm having the same problem on my 75 Scirocco. I finished getting the old wheel well out yesterday and of course the new one is slightly larger.
I drilled the spot welds on the joins on the top and sides. Then used a ratchet strap to pull the circle tighter as it was dropped into place. Obviously so far in you will need to move the strap to the under side of the floor or tap it down with a block of wood and a hammer from the top. Hope this helps mate
Missed it by that much Don Adams - YouTube
