Just a quick tidy up..........Oops!! (UPDATE 22/06/10)
![Avatar](https://i52.photobucket.com/albums/g19/blans/Various/rsz_1frontgolf_zps6cddabf6.jpg)
Twitter Manager
![blans in the usergroup ‘Paid Member’ blans in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![blans in the usergroup ‘Old timer’ blans in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
:mrgreen:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/102_0022_renamed_15080.jpg)
![bazmk1 in the usergroup ‘Old timer’ bazmk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
daztheoneclaw said
bazmk1 said
Hi
Just read the thread from start to finish - good read & some good work
How easy is it to Zinq plate , do the items have to be cleaned thoroughly before the zinq plating will work , if so how do you clean the items? Im thinking about going down this route but not sure yet
baz
Thanks for the positive comments chaps. Helps to keep the motivation going. 8)
The plating is very easy. I have a small shot blaster so i use that to clean up parts or a wire brush on a grinder and rusty parts left to soak in vinegar over night works a treat too. Once they are clean you just wash the parts in a solution that is provided in the kit. For small parts i mix a small amount with water and put it in a small tupperware type box with a lid. Add the parts and shake vigarousley!! For larger parts dip a sponge in the solution and scrub. Its a bit of trial and error as to how long you leave stuff in for but the results can be pretty decent. Good luck with it![]()
![davevw67 in the usergroup ‘Regular’ davevw67 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![daztheoneclaw in the usergroup ‘Local’ daztheoneclaw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
blans said
Your attention to detail….. No sorry I Mean fanatical obsession has to be commended. Absolutely amazing build.
:mrgreen:
Thanks for the comment. The lads at work do call me OCD Daz :? I just want it to be the best that i can get it and to be honest im probably 95% happy with it. If i started again there are some bits i would change 8O .
davevw67 said
where did you get that heatshield from,obsolete i was told by lookers teeside..
It was in the for sale section on here mate. Lucky find. There is actually another half to it that i am missing as it sandwiches the down pipe.
![Avatar](https://i2.photobucket.com/albums/y23/redpetemk1/avtar.jpg)
![redpetemk1 in the usergroup ‘Old timer’ redpetemk1 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Theres nothing better than refurbing bits, no matter how small
Keep it up, will be a very special mk1 when its finished.
Pete.
![Betts1411 in the usergroup ‘Regular’ Betts1411 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/half-life.jpg)
![jellybelly in the usergroup ‘Paid Member’ jellybelly in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![jellybelly in the usergroup ‘Regional Hosts’ jellybelly in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![jellybelly in the usergroup ‘Old timer’ jellybelly in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
It was a lot of fun and I just wish i had had the time to finish it, but that's it, its gone and so am i ……………….. I may be back…………… who knows!! :ninja:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Hairyarse said
We may see you back then!![]()
I hope so mate.
Ive got a house to build……… but once that's done I suspect that the lure of a Mk1 will be hard to resist.
Later guys!!
