Roof lining mk1 gti tin top
(In Topic #212483)
![Deank in the usergroup ‘Newbie’ Deank in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
I'm sure a kettle, radio and a bit of time should do it, any recommendations on glue??
A freind of mine used spray glue for his 60's daimler and the headlining just fell off. As such he went and bought some of this:
http://www.ebay.co.uk/itm/HEAVY-DUTY-HIGH-TEMPERATURE-CONTACT-ADHESIVE-GLUE-1ltr/220463087601?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
and I did the same.
You spread it on to the lining material and then spread it on to the car. Let the fumes come out of it (keep lots of fresh air around you or you'll be seeing little Unicorns ala Deadpool) and for it to mostly dry and then stick the two together.
Be careful though as once it's stuck it's on there. It will come off if you need it to for a bout 2 mins or so. After that it's on there!
Get lots of razor blades. They are the best thing for doing all the trimming of the excess. You don't need any pressure as you do with a stanley blade so no marking the paint.
I also lined the roof panel, A, B and C pillars and across the top of the panel between the B and C pillars with some 5mm foam.
http://www.ebay.co.uk/itm/1mx5M-Roll-Car-Sound-Proofing-Deadening-Van-Closed-Cell-Insulation-Foam-UK/122545178632?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Just makes everything feel a bit nicer.
We also added some trim bits between all the sections, just to 'finish' it a bit
![SG100065.JPG SG100065.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1500199375/uploads/attachments/596b39cdc275f.jpg)
![SG100066.JPG SG100066.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1500199378/uploads/attachments/596b39d118349.jpg)
![SG100067.JPG SG100067.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1500199380/uploads/attachments/596b39d3c3940.jpg)
It took us about 14 hours to do it all and we had no windows in and no interior at all.
Take some measurements as to how far it comes down the 'B' pillars before it get glued and where it is glued across the rear panel above the tailgate.
Unfortuantely I didn't do this and it's glued a bit too far, so it's a bit different to how VW did it.
Might also be worth getting some new rubber/plastic ends from Classic VW for the steel bars in the roof as mine all broke when removing them.
Good luck
Ian
Cut the wire so it's the same length as the distance between the seals. Cut the vinyl longer and about 2" wide. Glue the inside faces of the vinyl. Add some small guage wire in the middle and fold the two face together.
The glue into place on the headliner.
We then glued the A, B and C panels overt the top.
Ian
Backinblack said
I used the spray glue from heritage. It was fine with me. Light sqeeze and like silly string. Heavy sqeeze and it fans out for areas like c pillar. Be careful if you use brush glue as too much can soak through and stain the lining.
Hadn't thought of the staining!
Good point!
My headlinng is thick black vinyl so no issues.
Good catch
Ian
![IMG_1662.JPG IMG_1662.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1500207279/uploads/attachments/596b58ae4ca4f.jpg)
You'll need a wide ended paint scraper and some white spirit to get the tar they used to glue to the bits of sound deadening in with.
It goes everywhere as well. So i'd suggest taking out the seats too.
I cut one large piece of foam. Ironically the width of the roll of foam is just about right for the width of the roof.
Cut it a bit overlong and trim to required length.
Get one of these too
http://www.ebay.co.uk/itm/50mm-Auto-Car-Sound-Deadening-Application-Rubber-Roller-Black-Clear-/282569143309?hash=item41ca6ef40d:g:cgQAAOSwlRpZZoiP
That way you can be sure the foam is well stuck.
Ian
I use a plastic disposable knife to spread, that way any overload can be spread out or off. Not a fan of spray glues. But yeah you High Temp Contact Adhesive.
