Mellow Yellow 3.2ltr 24v Conversion
Then to finish off used Luxury liner pro.
Tonight i sprayed on some more epoxy to seal the areas I sanded. At the weekend I will finish final spots and move on to high build
Giving me plenty of ideas for my own project
Sent from my E5823 using Tapatalk
Bit of a slow down recently, the grey epoxy I sprayed on seems to have softened in places after spraying polyester filler. The products were from the same company and were compatible but I believe the Xylene thinners caused the issues. Anyhow it's starting to harden now which is the main thing but this is how it looks now.
Last edit: by Rich.
Soaked in rust remover to start
Then brass wire wheel
Then back in the rust remover solution for the night
Last edit: by Rich.
Last edit: by Rich.
another soak in Bilt Hamber Deox C
I gave them a further soak and left them for 24 hours then rinsed them off and used POR 15 metal ready to neutralise and zinc phosphate coat them until I get round to painting them.
Ordered up a full caliper and carrier rebuild kit including new pistons
Last edit: by Rich.
Last edit: by Rich.
Last edit: by Rich.
A bit more Bilt Hamber flat face sprayable filler.
Last edit: by Rich.
Last edit: by Rich.
Last edit: by Rich.
Matt
pazwaa said
Engine bay is looking very nice
Matt
Ditto!!
The calipers came up well too after a good soaking
I have primed everywhere a couple times and seam sealed where required.
I put Upol Gravitex stone chip on Friday which came out better than I expected. Will do one last prime and flat down tomorrow.
Tuesday this week everything will be body colour
Last edit: by Rich.
Last edit: by Rich.
