84 MK1, head light popped off
(In Topic #211578)
![Golfgtijl in the usergroup ‘Newbie’ Golfgtijl in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Head light popped off bracket
![IMG_0795.JPG IMG_0795.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1495488797/uploads/attachments/5923591ba933c.jpg)
![IMG_0796.JPG IMG_0796.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1495488800/uploads/attachments/5923591f90a8e.jpg)
The head light on my 84 Mk1 GTI popped off round the frame yesterday, looks like the round rubber piece is perished. Anyone know where I can get replacement rubber seal, what type of glue I should use to glue it all back together?
Thanks,
John
Last edit: by Golfgtijl
Pics work well to show the issues.
It's the outer larger main headlight..
It appears to have a specially fitted rubber seal, which assume glues back on to the round frame around the light.
I'm new to the forum, also wondering if I posted this in the right area?
Thanks again,
John
![Daytona in the usergroup ‘Paid Member’ Daytona in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Daytona in the usergroup ‘Old timer’ Daytona in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Marcus.
Daytona said
Remove all old stuff and clean all up.Just use good quality silicon, it works perfectly. Put it all around inner parts edge making sure its good all around especially on the top to keep water out, then line up headlight and push on. Tape in place with masking while it dries. Same happened to me with mk2 recently.
Marcus.
X4
They Glue Aquariums together with clear RTV you can too. Give it s good 24 hours to cure or dry. Then run a bead of it around the outside to fill any voids in the sealant so water can't ingress.
Just be careful not to get any on the reflector. Or OOzY out towards the inside Clean smooth both edges, and apply a smaller diameter hole. Squeeze from the bottom of the tube as you get a better consistent flow from the tip.
