Sump bolts
(In Topic #211279)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20170805_180530.jpg)
![marcsa3 in the usergroup ‘Local’ marcsa3 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sump bolts
![20170506_153704.jpg 20170506_153704.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1494083087/uploads/attachments/590de60ddc4c4.jpg)
I am trying to fit a new sump but trying to tighten these two bolts up is a right headache as when I offer the sump up there is limited space to get a socket and wrench in the gap and the extension bar needed to do it catches the gearbox casing causing the bolt to go in at an angle and almost cross threading the block.
Is there any trick to this as I have tried a flexi extension and allsorts with no joy..
1990 Golf GTI cabrio 1.8i. DX Engine
![lukecab in the usergroup ‘Regular’ lukecab in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
The first one or two threads on the block are slightly damaged which doesn't help but if I can get the bolt in square it will eventually tighten.
Fingers crossed and thanks for the advice. .
Have tried using an elbow joint to get in there but no joy Im afraid.😷
![](https://76.my/Malaysia/sata-2-stage-wobble-extension-bar-11903-open-stock-ehardwarestore-1112-27-aaronngu77@12.jpg)
Cheers mate, off to the shops..!
You can change the bolts to Allen key head bolts and get an Allen key tool with a ball head to allow you to use it on an angle.
It looks like someone has already changed 1 bolt, I would fit a locking washer as the original bolts have groves in them to stop them rattling lose.
I found fitting those bolts in 1st did help a little but you have to hold the sump up and try to fit a bolt, not the easiest thing to do.
Having to keep the sump up with my head at times and not being able to start the thread off with my fingers has took me 2 hours so far.
Not the best design but it will get done somehow. I'm hoping…
On one of my rides the rear crank seal carrier was previously stripped, so to "fix it" I used 2 sheet metal screws on those two worked just fine…. (of course it isn't Kosher, but I don't have the leak I had, and I figure the next time I pull the tranny I will replace the rear seal carrier and seal…. But those are two of the Vexiest Bolts that I know of.
Nice shiny new sump and fingers crossed no leakage once the oils in.
Thanks for all the help anyway guys.
![20170507_133442.jpg 20170507_133442.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1494180025/uploads/attachments/590f60b7e8310.jpg)
![20170507_133458.jpg 20170507_133458.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1494180027/uploads/attachments/590f60ba68221.jpg)
Have you got the cover plate to go on the gearbox near the bolts you was having trouble with?
Getting there slowly but hope to have it up and running by July and some decent weather.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1569895/CIMG9134_zpsse0tdpvg.jpg)
Nice job on the engine by the way. Looks tidy.👍
12 months later the black paint I used to paint the block is showing sights of rust coming through as I guess I did not prep the block enough, I just wire brushed and degreased before painting it with a brush.
The cars a daily so not overly worried about a bit of dirt etc..
![](https://vwgolfmk1.org.uk/uploads/pbextract/1569910/CIMG9329_zpspvc3byxq.jpg)
