Mellow Yellow 3.2ltr 24v Conversion
You've got a lot of patience Rich  :thumbs:
Tedious innit, welding up all them holes  O_o
That stiffener bar looks interesting  ;)
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Had a bout of the old man flu that knocked me for six so haven't had much progress the last 2 weeks but managed to get some time in today :)Welded the holes I don't need in the front panel, top and front edge and also the tops of the turrets
Last edit: by Rich.
I have some wheels I really want to fit but the offset isn't particularly forgiving with G60 calipers.
I dug out my old Gti 256mm calipers with the special carriers that fit the mk1 hubs. Going to trial fit them to see whether they are a better fit with the wheels. Also nice to have a direct fit caliper than using an adapter.
Last edit: by Rich.
The Yellow Peril R32
Great build mate , brave fella, was this car in golf mag? Previous owner a woman? Looks familiar well she had g60 in her yellow golf. Have g60 in my wagen love the sound although my cuz has vr6 in his mk2 equally nice sound ,funny he has v5 box in his golf and it's got better ratio than vr6 box so he reckons. Best of luck with the build, what are the brake carriers of by the way?
Nah not been in Golf mag and no the previous owner wasn't a woman. I put a G60 conversion in her, lasted for a year before I changed my mind and went R32 lol
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fthe-yellow-peril-G60
The brake carriers are from an early Scirocco I believe
Had a read of your g60 build thread / money pit , I remember it well. Did u ever   get it rolling roaded? Didn't see any figures, there some machine in g60 mode, also when r.j did the wiring loom are all the connectors included or is it just wiring ?
Never got it rolling roaded, but hey it's not always about the figures, just how the car drives and it sure did that.
I got new connectors where possible and used the existing g60 ones where they were no longer available.
Yep there a beast of a car with g60 engine and you can throw it into bends , corners and with confidence it'll go where you aim it, mine is polybushed all round and like a go kart , be interested to see what you will make of the new engine
Got the accelerator pedal bracket fabricated :)Now I can finish off the last bit of grinding and then the sand down begins :)
Last edit: by Rich.
Great work, really looking forward to watching this progress. Like you say there ain't much info or guidance out there on this conversion yet.
That engine bay will look slick when finished  :thumbs:
Keep up the good work, it's threads like this that keep us all motivated!
Cheers Stevie :)
starting to pick up momentum now, only managing to work on the car at the weekends but have some days booked off to speed up progress  :thumbs:
I want to improve the stock sound proofing so the interior is more bearable as the G60 was pretty loud and I'm not too sure about how loud the R32 will be :lol:. Also there was a lot of heat radiated from the engine through the bulkhead and without the stock heating system I'm not sure how good the air flow will be :)So I undertook the thankless task of removing the stock bitumen sound proofing which also gave me the opportunity to inspect the floor for any tin worm.
Before:
Some heat gun and scrapping action:
Started removing the residue:
Finally got there :) gallery_23668_521_39540.jpg
Thankfully no signs of rust and original floor:
Next going to sand it all down and get some epoxy primer on :thumbs:
Last edit: by Rich.
Started today by removing everything from the engine to do the timing chain and replaced everything with new VW goodies :) gallery_23668_521_165012.jpg
Chain and guides removed
Old bits
new bits on :) gallery_23668_521_53408.jpg
Also started to remove the 5th gear from my CTN diesel box to go in the CDM Corrado box.
Tomorrow I will finish off the gearbox and start fitting the service parts to the engine :D
Last edit: by Rich.
Great work. Your floor looks in great condition  :thumbs:
Matt
Managed to crack on :)Serviced the engine, new iridium spark plugs, water pump and oil filter. Added my mocal thermostatic plate.
Modified the alternator bracket so the air con section is removed for more clearance. Added a new diesel alternator with W terminal and mounted up the tensioner so i could trial fit the V belt. Success .
Last edit: by Rich.
Gearbox is now finished, managed to take the gears off without damaging the teeth.
Next I'm going to remove everything and paint the block and gearbox. Hoping for a trial fit week Friday.
The interior and exterior are on pause at the mo, need to check the radiator, fan assembly and oil cooler fit and the necessary brackets fabbed up before i touch the prep and paint.
Re:
Matt
Cheers Matt
Sent from my Nexus 4 using Tapatalk
It's getting ever closer!!  :cool:
Pics of the diesel 5th gear installed, trying to assemble the selector was interesting with the c clips. Think i might be a bit cautious when i first give the box a dry run
Last edit: by Rich.
