Saulty's 1983 Tintop 1.8GTI
![IMG_6053.JPG IMG_6053.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846320/uploads/attachments/5834a9af45c60.jpg)
![IMG_6053.JPG IMG_6053.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846323/uploads/attachments/5834a9b211f90.jpg)
![IMG_6053.JPG IMG_6053.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846325/uploads/attachments/5834a9b4bb4cf.jpg)
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846963/uploads/attachments/5834ac31dbd27.jpg)
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846966/uploads/attachments/5834ac34de9d8.jpg)
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846969/uploads/attachments/5834ac382c54d.jpg)
Once I had got the angles correct and welded I ground down the welds with a dremel and then cut it to shape so that I could but weld it to the existing skin and then zinc primed it
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846973/uploads/attachments/5834ac3b68ccc.jpg)
I then welded the new section to the existing skin and ground down the welds with the dremel. That took some time as well.
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846976/uploads/attachments/5834ac3f4ac80.jpg)
I then cut the new section to shape, I made a mistake here by cutting it in a straight line rather than to the line curved line of the doors original shape, this became obvious later when I folded the outer skin around the inner.
![IMG_6075.JPG IMG_6075.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479846980/uploads/attachments/5834ac43a10ba.jpg)
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847940/uploads/attachments/5834b002a84b7.jpg)
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847943/uploads/attachments/5834b0063a412.jpg)
Once I had welded the new section I folded it around the inner skin on the leading edge and put a generous amount of sealer in there and then ground down the welds.
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847946/uploads/attachments/5834b008d1e8d.jpg)
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847948/uploads/attachments/5834b00b92da3.jpg)
Then I removed the old stripes and paint all along the door bottom and filled ready for paint! I seem to have been slack on the photos when filling as I don't have any. I also hate it and I'm not that confident in doing it.
Then came the rattle can spray job!
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847951/uploads/attachments/5834b00e3114c.jpg)
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847953/uploads/attachments/5834b010d6e43.jpg)
![IMG_6178.JPG IMG_6178.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479847957/uploads/attachments/5834b01428d69.jpg)
All in all I am quite pleased with it. The line of the leading edge is too straight and the rattle can spray job is not the best but hopefully it will hold out and look good once I have the stripes on! I also gave it a very generous amount of cavity wax to help protect it from the inside!
![JackWealdCoachworks in the usergroup ‘Regular’ JackWealdCoachworks in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![chrisL in the usergroup ‘Local’ chrisL in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Well impressed!! What filler did you go for in the end and did you get a long sanding block?
![](https://emoji.tapatalk-cdn.com/emoji1303.png)
![](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
Onto the drivers door next!
![IMG_6431.JPG IMG_6431.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489701483/uploads/attachments/58cb0a6a05906.jpg)
![IMG_6441.JPG IMG_6441.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489701487/uploads/attachments/58cb0a6d8f5ff.jpg)
![IMG_6445.JPG IMG_6445.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489701490/uploads/attachments/58cb0a70ebda1.jpg)
![IMG_6454.JPG IMG_6454.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489701493/uploads/attachments/58cb0a73c6e46.jpg)
![IMG_6511.JPG IMG_6511.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489701496/uploads/attachments/58cb0a76dc893.jpg)
![IMG_6527.JPG IMG_6527.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489702230/uploads/attachments/58cb0d5313178.jpg)
Here's a pic!
Hairyarse said
Tidy job. I agree that you want the bracket there. Having the scuttle flexing due to the motor can't be a good thing![]()
Thanks Andy, i know others have left out the bracket but there was quite a bit of movement and I just wouldn't have been happy driving it too far with the motor swinging about on it's mountings.
Going to attempt a few more pics in a minute!
![IMG_6541.JPG IMG_6541.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489788772/uploads/attachments/58cc5f624e5a8.jpg)
![IMG_6543.JPG IMG_6543.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489788775/uploads/attachments/58cc5f65d443a.jpg)
Cut out the rusty metal…..
![IMG_6546.JPG IMG_6546.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489788879/uploads/attachments/58cc5fcec133c.jpg)
![IMG_6547.JPG IMG_6547.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489788883/uploads/attachments/58cc5fd1ddc76.jpg)
![IMG_6548.JPG IMG_6548.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489788886/uploads/attachments/58cc5fd4e5d65.jpg)
…..and cut to shape and welded to get the right angles a repair section for the inner skin I made when I did the passenger door and welded it to the inner skin.
![IMG_6545.JPG IMG_6545.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789155/uploads/attachments/58cc60e1a0689.jpg)
![IMG_6550.JPG IMG_6550.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789158/uploads/attachments/58cc60e516218.jpg)
![IMG_6551.JPG IMG_6551.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789161/uploads/attachments/58cc60e7da233.jpg)
![IMG_6552.JPG IMG_6552.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789163/uploads/attachments/58cc60ea6f509.jpg)
When I did the passenger door I cut out the old metal to a line parallel to the swage line but when I welded in the repair section I had a bit of heat distortion in the swage line which was hard work to get right so this time I cut at an angle to get as far away from the swage line as possible. I tacked the repair section into place and refitted the door to check the gaps and then removed the door again to weld the section in fully. I then re-hung the door again before the sealer went off between the inner and outer skins to check the gaps.
![IMG_6549.JPG IMG_6549.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789449/uploads/attachments/58cc6207df8dd.jpg)
![IMG_6553.JPG IMG_6553.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489789451/uploads/attachments/58cc620a860d8.jpg)
![IMG_6556.JPG IMG_6556.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791454/uploads/attachments/58cc69dd3283c.jpg)
![IMG_6557.JPG IMG_6557.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791457/uploads/attachments/58cc69e05e012.jpg)
![IMG_6558.JPG IMG_6558.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791461/uploads/attachments/58cc69e338def.jpg)
Then it was time for some rattle can paint!
![IMG_6579.JPG IMG_6579.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791510/uploads/attachments/58cc6a1556dc1.jpg)
![IMG_6580.JPG IMG_6580.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791513/uploads/attachments/58cc6a18292e0.jpg)
![IMG_6581.JPG IMG_6581.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791515/uploads/attachments/58cc6a1a8112c.jpg)
![IMG_6582.JPG IMG_6582.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791715/uploads/attachments/58cc6ae1daeb7.jpg)
![IMG_6584.JPG IMG_6584.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791718/uploads/attachments/58cc6ae4aaafe.jpg)
![IMG_6585.JPG IMG_6585.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791721/uploads/attachments/58cc6ae83eeb2.jpg)
![IMG_6586.JPG IMG_6586.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791724/uploads/attachments/58cc6aeb2ef8e.jpg)
And then the passenger door!
![IMG_6589.JPG IMG_6589.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791778/uploads/attachments/58cc6b209876c.jpg)
![IMG_6590.JPG IMG_6590.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791780/uploads/attachments/58cc6b2387f1b.jpg)
![IMG_6591.JPG IMG_6591.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791784/uploads/attachments/58cc6b269bfad.jpg)
![IMG_6595.JPG IMG_6595.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489791787/uploads/attachments/58cc6b2a1e616.jpg)
![IMG_6612.JPG IMG_6612.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489792219/uploads/attachments/58cc6cd7504db.jpg)
![IMG_6614.JPG IMG_6614.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1489792222/uploads/attachments/58cc6cdcda8d5.jpg)
Ratlle can paint match looks good too - not easy on red.
Happy days
![](https://emoji.tapatalk-cdn.com/emoji41.png)
