Shellby - 83 gti ABF on carbs
mk1 Jamie said
OO Nice haven't checked on this for a while …Love the underside colour coded makes me wish id done mine
Jamie
Thanks Jamie
The underside colour will only last till the cars first trip, and the guy who painted her kept asking why I wanted the bottom blue, but after seeing other cars done this way, and how good it looks for resto photos, I'm so glad I did.
Matt
Happy new year to all you mk1 people
Went down to the old barn, see if my car is still there
She's still there, but been shoved into a corner! Out the way!!
Hopefully I will progress much more this year, need to pull all the parts out and remind myself of what's to be done. Fingers crossed.
Matt
Looking forward to updates
Went down to see her again and got very little done
Moved all my junk around so I can actually work on the car
A very small space, but can now crack on with the engine bay components.
Got myself a steering rack boot from eBay. And also ordered some fixings so I can begin the suspension. Hopefully some decent progress this week. Hopefully.
can see from your pic you have one of each
rubjonny said
thats just for the boot to seal to. some need that as the outside hole in the boot is big, some dont need it as the boot hole is small.
Cheers John, the font of all knowledge as usual 👍🏼
Hopefully that means I aren't missing one.
Love the colour and the colour coding to the underside is sweet
Question for you, in the picture, just above the tap, you have a square plate. Is this something you installed? Is it a jacking point or something else?
http://s1064.photobucket.com/user/pazwaa/media/Shellby/5777DC85-8A5A-4258-ACBA-5BFB71F42B5D.jpg.html
Cheers, Ian
Keeping the colours simple, either blue or black.
The plate is a jacking point I fabricated myself. I once had Porsche alloys, so I bought a Porsche jack too, the oval slot locates on the jack. Don't have the wheels anymore, but liked the jack so kept it
Matt
Ordered some black fixings to bolt the strut brace and adjustable top mounts on
Then dug the avo coilovers I bought many years ago out
Fitted the modified hubs to the wishbones
And front suspension mocked up
Ordered some black bolts for the hubs and need to fit the springs to the struts.
Is there a way to compress the springs and fit them without spring compressors?
Thanks for reading 👍🏼
Matt
could try cable ties to compress them, but it depends how stiff they are
As rubjonny said, should'nt need to compress the springs on coilovers, (well I never have had to)
Looks like the piston needs extending out from the shock body. Pull down on it as its mounted now and it should reveal more of piston.
5 stud hey? I'll have to read back through the tread
Didn't know you could extend the piston, rookie error, that should solve my problem, cheers 👍🏼
Yep, 5 studs on 114 pcd, bit of a nightmare that's what happens when you impulse buy shiny wheels without checking if you can actually fit them
Matt
And got the hubs fitted
New track rod ends
New steering rack boots
Refurbished steering rack
And loosely put in position
Got a bit of fiddling to get the bushes in the clamps and the clamps on the mounts, but the engine bay is beginning to fill out nicely
The suspension is top adjustable. Can someone explain how they lower the car? Do you turn the knob at the top and this reduces the length of the strut, thus lowering the car? Is the collar under the springs to tension the spring only?
Matt
Isn't the damping rate adjustable from the top and then height adjustable using the C spanner on collar ring?
Found this on the AVO site:
ADJUSTMENT Top adjustable struts and inserts have approximately 10 settings. On top adjustable units there are no positive clicks to the feel of the adjustment, therefore half turns are equal to one setting. Base adjustable units have approximately 16 adjustments which can be felt by a positive click when the adjuster is turned with the use of a 4mm allen key tool On front and rear units clockwise adjustment is to stiffen the damping rate and anti-clockwise will soften the damping rate.
On units with adjustable spring seats an appropriate tool should be used to wind the platform up or down the threaded body of the damper. This will increase or decrease the ride height of your vehicle. It is very important to maintain the thread of the damper by regular cleaning and re-greasing in order to keep the smooth operation of the spring seat adjustment. Also the adjustment controls for the damping rates should NEVER be forced past the minimum and maximum stop settings.
http://www.avouk.com/Downloads/Guidelines.pdf
I bought these off eBay many moons ago and they didn't come with any information. They look like the GTZ version.
I'm probably getting this wrong, but I guessed that to raise and lower the car, the length of the strut needs to increase or decrease? I thought with the car weight on the top of the spring that winding the collar under the spring would just compress it? But that doesn't seem right. Confused!!!
pazwaa said
Thanks for the info Rich.
Wind them down for lower, wind the up to go higher
