dash lights and gauge problem
http://www.ebay.co.uk/itm/VW-Golf-Jetta-Scirocco-Mk1-Mk2-DASH-BULBS-2-0W-Bright-Speedo-Clock-Pack-of-4-/291443293161?hash=item43db5fbbe9:g:eNoAAOxynLhR~iGY
I think that connection is for the MFA?
Do you have a picture of the LCD on the front of the instruments?
if that checks out loop a wire between the red/white and the white wire and your indicators should work. If they do replace/fix the hazard switch, if not check the wiring back to the fusebox and the hazard/indicator relay
You could pull your switch apart again and check you have all the springs and brass connection in the right places.
Just keep an eye out on the floor incase you spot them at a later date and can repair the switch.
(Also added the headlight upgrade kit but that's not related)
Reconnected it all and have the following:
1. Instrument cluster lights up nice and bright. Ciggy light also comes on.
2. But no lights to all other dash switches
3. Front windscreen wipers are constantly on!
4. Im wondering if i joined my new instrument cluster earth to the wrong cable on the long connector. I used second from the left, which seemed to be the only brown one.
5. Also, i havent connected up the light ‘fader’ switch on dash RHS yet. Could this be breaking the circuit to the dash switch bulbs?
Thoughts or advice please?
Last edit: by gregpank
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Any thoughts on my wipers constantly running?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Wipers running Constantly before or after the change?
Before Try re-seating the relay.
After then re-seat the relay, and then look to the wiring.
Best Tip Ever:
Solder/Heat Shrink all connections.
Firstly thanks for your odometer repair guide. Did it a few days ago and went out for a short drive today and it works! I clocked up a couple of miles. Awesome - thanks.
Back to the problem in hand…
So it seems the ciggy lighter and light run off a different circuit then the rest of the dash switches.
This is working fine and the blue/grey wire is working but has this strange fitting. It looks as though something should plug into that black connector?
I noticed on the heater controller, 1 of the 4 connectors doesnt connect to anything off the switch. Are these circuits related?
Also, there are no grey/blue wires on any of the other dash switches which arent working. Theyre all brown:
Incidentally i also adding a new ground from the coil clamp to the cam cover as recommended.
Wipers: only starting doing their own random thing after the instrument cluster repair and new earth wiring being added a few days ago.
Sorry to fire so many things at you!
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Ok so had another go…
Turns out the fog, hazard and heating screen switches were all pretty filthy. So a bit of wet and dry sanding and those 3 are now working!
Handbrake light on RHS isnt working but think that may actaully be the switch under the handbrake itself.
Still ant figure out the wipers though….
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
gregpank said
Update:
The wipers have a permanent live for the self parking feature,have the wires been disturbed or swapped?
