REMOVING FRONT AND REAR SUBFRAMES
(In Topic #208485)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/eagle.png)
![Adam88Binks in the usergroup ‘Newbie’ Adam88Binks in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
Jacking Points
im going to be removing all teh subframes so i can have them powdercoated.
where is the best place to put 4 axle stands?
thank you
adam
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/simon.jpeg)
Chairman
![36thcrazyfist in the usergroup ‘Moderators’ 36thcrazyfist in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![36thcrazyfist in the usergroup ‘Paid Member’ 36thcrazyfist in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![36thcrazyfist in the usergroup ‘chairman’ 36thcrazyfist in the usergroup ‘chairman’](https://vwgolfmk1.org.uk/themes/default/images_custom/alETPUG.png)
![36thcrazyfist in the usergroup ‘Administrators’ 36thcrazyfist in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
There's jacking points (at the from) by the sills, just use some wood to avoid damage.
When I dropped my rear beam I used some blocks of wood between the floor and the sill, it's not the most secure but avoided any damage, I believe there's jacking points right at the back, at least there is on cabbies!
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20111015_063708676.jpg)
![mattn in the usergroup ‘Paid Member’ mattn in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![mattn in the usergroup ‘Old timer’ mattn in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I found using axle stands lined with some thick carpet worked a treat and did not damage things at all.
Try to have the rear of the car up as high as possible to make access easy….and use plenty of plus gas on the bolts for a few days before removing.
Chairman
Follow us on:
Follow us on:
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_20151111_162200.jpg)
![D_Martijn in the usergroup ‘Old timer’ D_Martijn in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Chairman
Follow us on:
Follow us on:
I would not work underneath a car without them.
