whining bearing noise when reving the car 1.8 gti,
(In Topic #207645)
How about the cambelt idler or an associated part? Or something as daft as the cam belt cover rubbing on the belt. You should be changing the belt anyway if its been stood idle that long.
Backinblack said
Trust bearing does it disappear when revving with the clutch down?
Yomp said
If its from the front it wont be oil pump as that sits underneath the dizzy.
i pressed the little red button
did you ever obtain a solution to this problem? My car is doing the same thing. 1.8 1983.nigelmc99 said
yes I replaced the cam belt and idler before the engine went back into the car , the whining noise comes in when the car heats up after running for about 5-10 mins, I removed the top cam belt cover to check for any rubbing , all was clear, I removed the fan belt to rule out that the alternator and water pump where ok , when I rev the car it sounds ok no whining , then when the revs die off the bearing whin noise comes in at the end , any ideas !!!
