Oil Light
(In Topic #207096)
![Avatar](https://i584.photobucket.com/albums/ss281/thejaychild/DSCF0002-1.jpg)
![thejaychild in the usergroup ‘Paid Member’ thejaychild in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![thejaychild in the usergroup ‘Local’ thejaychild in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Sorry
Im sure this has probably been covered no end of times but i can seem to find any answers to my exact problem..
My oil light is dimly lit when drive and shine's really bright when i accelerate its never 100% off
I have checked the level of a number of times and it seems i have plenty.
The engine is 1.8 carb auto
Thanks is advance
Jaxon
![Ashton09 in the usergroup ‘Paid Member’ Ashton09 in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Ashton09 in the usergroup ‘Local’ Ashton09 in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Goes bright when put lights on
But mine it's the cluster what's broke
Why I put Vdo gauges in so I know what it's doing as a gauge better than light anyway if you light come on when driven damage allready done with gauge can see before that point
Or just buy cheap gauge set buy all 3 with senders off eBay about £15 easy to wire up
Engine/Tranny to Main Frame, then Battery Negative to Frame.
Also the clusters have pin 2 (brown) to a Star connector on the inside firewall that is know to get tarnished or corroded. So I advocate adding a new earthing point for that wire to behind the cluster to Frame.
It could also be that your 10V stabilizer is going out, but that too is an easy test that is outlined in the Bentley.
On my older Golf Diesel I would see a glow when my oil level was about 1 quart low on oil.
Lastly, the oil pressure senders have been known to get wonky and need replacing.
I will let you know how i get on.
