GTI ENGINE MODS ADVICE NEEDED !
(In Topic #205530)
I have recently fitted my new engine in ( 1.8 8v gti) and need to start unleashing some power ! Just need some advice really about my planned mods to find out if they are all compatible..
My engine as it stands now :
Lightened and balanced crank
All new rings and bearings
Tsr style big valve head
Ported and polished
Piper 285 camshaft
At the moment it is still running the standard throttle body and injection system but I have or would like to fit the following:
Mk2 throttle body
Mk2 16v wur
1.6 gti metering head (have read that it flows better and my one is suspected to be duff lol )
K&n airfilter ( standard panel filter not induction box)
Would this combo be ok ? Sorry if this is a bit long winded haha. Thanks, jake.
This is the throttle body i plan to use. Could anybody tell me which vacuum outlet on the tb should be used for the 16v wur ? Also where can I get a fuel pressure gauge to test it all ?
Regards Volkswarren
Website Manager
Getting tempted to go down the megasquirt route as ive had no end of trouble with the k-jet.
One minute its fine and then out of nowhere it just wont idle properly… the joys of classic cars eh ?
Mine has 16 previous owners, all of which have bodged everything !
A stand alone ecu system based on later digifant hardware would work nice but not cheap.
www.jmrclubsport.com
The only thing with twin webbers ect is that its hard to find a decent set and new ones are about as pricey as going down the megasquirt route. At least with megasquirt you get the mapping to really dial it in.
The car is booked in with my local tuning guru in a fortnight so I'll be chucking in a new clutch to handle the rolling road. He will be doing the wur as well as fine tuning the cam timing and overall fuel system.
I think the 1.6 metering head should work although the pipes for the fifth injector and wur are different ?
Yes good weber's arnt easy to find and not everyday road friendly…even the most enthusiastic owner will soon get fed up with the noise every day…B road blasts and track day's are a different matter!
I put the larger throttle body on today and its a lot more responsive. Just waiting for new airfilter and clutch then she's of to the rolling road !
Do any of the ecu's alloy multiple maps to be switched without a laptop at hand ?
Thanks for your input once again !!
Aw thanks!…they need updating badly as there's a lot more these days….180hp race mk1 1900 8v, 214hp 2ltr race mk1 8v crossflow, 230hp track day 2ltr mk1 16v, forrest rally 240hp mk2…etc.
The need for multiple maps is a bit of a myth with programable stand alone ecu''s…when mapped properly you get the best of full power performance at full throttle and part throttle economy when crusing…or at least you do when we map them. I've got a customer with an awesome road mk1 with an 1800 crossflow on throttle bodies that makes 160hp and pulls like a train on the road while giving decent economy on motorway runs.
We've used emerald in the past but get better results these days with DTA, MBE and Omex ecu''s as theyre more modern with faster processing power.
Anything I can help you with Jake just ask…I'm as happy to help as sell parts and build engine's so don't hesitate to call/txt or email me on any of the numbers on my website.
Regards
Jason
Cant see me moving away from mk1's anytime soon so im investing in the best I can as I go along.
Brakes is the next on the list as the standard stuff is a bit bum clenching at times… lol
Cheers for the advice jason !
