Leaking Fuel Accumulator
(In Topic #205475)
![jossgoodhew in the usergroup ‘Regular’ jossgoodhew in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Which Accumulator to purchase?
so you'll want to get the small one, as you'll probably find the full size unit wont fit in the space you have. if it does fit then happy days, it'll work just fine
Thanks for the advice guys much appreciated. Happy driving.
![thexvw in the usergroup ‘Local’ thexvw in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
I do have a spare one if anyone is in need!
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/trees.png)
![aqueous in the usergroup ‘Regular’ aqueous in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
This is the direct equivalent to the repro version listed on VW Heritage for £180.
Thanks Joss for the pointer - been looking for one of these for less than the cost of the car…!
These accumulators at the link above have just been reduced - now a bargain at £67.24 incl delivery. Perfect opportunity to replace the one on it's way out…
![ivortheengine in the usergroup ‘Old timer’ ivortheengine in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
the post-84 cab and sirocco are an exception as they use a smaller unit which is in a different position. if you could squeeze the bigger unit in it will still work though!
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/music.png)
![One seven one in the usergroup ‘Local’ One seven one in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
rubjonny said
yes it will, same unit is used on the 1.6 and 1.8 kjet engines including mk2 golf 8v and 16v kjet cars.
Jonny do you happen to have a picture of where the accumulator is located on a mk1 cabriolet 1990
I have bought a new fuel pump and the correct smaller accumulator for it but can't see where it actually lives! Before i take it all apart it would be good to know what to expect
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/leech%20kr.jpg)
Regional Host NE
![nicci21paul in the usergroup ‘Paid Member’ nicci21paul in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![nicci21paul in the usergroup ‘Regional Hosts’ nicci21paul in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![nicci21paul in the usergroup ‘Local hero’ nicci21paul in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
Re:
![](https://emoji.tapatalk-cdn.com/emoji23.png)
Sent from my SM-G960F using Tapatalk
