Brake linkage lenth?
(In Topic #205445)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/gtiforever.jpg)
![Memorextape in the usergroup ‘Paid Member’ Memorextape in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Memorextape in the usergroup ‘Old timer’ Memorextape in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
194mm to chassis number 175 3 500 000 / 535 2 500 000.
172mm from chassis number 176 3 000 001 / 536 2 000 001.
Where as my chassis number is like WVWZZZ17ZDW******.
This is the linkage, how long does it need to be?
![](https://vwgolfmk1.org.uk/uploads/pbextract/1538144/IMGP5939_zpsiave60dy.jpg)
Your chassis number is the newer style 17 digit.
Basically, its 1975 models which are slightly different, 1976 models onwards are the same. And yours is a 1983 model (from the D year code).
Obviously the linkage basically sets the pedal height, so its not a critical dimension but there's an acceptable range there (so long as it allows full & free movement) and brake pedal position will also need to relate to clutch pedal height (I think there's a specification that they're 20mm different or something?) and you'd also need enough clutch pedal movement to fully disengage the clutch.
I'd not worry about it too much, given it can be later adjusted if needs be.
