noisy tappetts
(In Topic #205223)
![sparkstu in the usergroup ‘Paid Member’ sparkstu in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![sparkstu in the usergroup ‘Old timer’ sparkstu in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
When mine are some times noisy when cold I can hardly hear them unless I have the window open, they usually quieten down after a few minutes or if I rev the car to above 2000 rpm then left the revs drop to idle but mine only tap on tick over.
I think the can check the gaps if you think there is something wrong with them, the Haynes manual tells you the gaps but no 100% sure you can do this with hydraulic tappets?
I would check for anything else that could rattle, heat shield on exhaust etc.
