How to spruce up your dash lights for 2 quid.
(In Topic #153412)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMAG0048-1.jpg)
![r_chez_08 in the usergroup ‘Old timer’ r_chez_08 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I noticed that on my car, the dash lights hardly did anything. I was considering removing the green filter and lining the light box with tin foil, but then I decided on LED's.
Bought a super bright 12 led strip from eBay, let the pics talk.
Firstly I removed the bulbs from their holders.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1276918/IMAG0378_zps3aec576f.jpg)
Then I soldered some wires to the holders
![](https://vwgolfmk1.org.uk/uploads/pbextract/1276918/IMAG0379_zpsca7a1b90.jpg)
Then some wires to the led strip.
![](https://vwgolfmk1.org.uk/uploads/pbextract/1276918/IMAG0380_zps619cfe75.jpg)
Self adhesive 3m backing held the strip in place
![](https://vwgolfmk1.org.uk/uploads/pbextract/1276918/IMAG0381_zps9b1699ac.jpg)
In car
![](https://vwgolfmk1.org.uk/uploads/pbextract/1276918/IMAG0382_zps6da17d2f.jpg)
What do you guys reckon?
I left them green for a more oe look and there's a good reason most dash lights are green. They are so much better than before, and still work with the dimmer
![](https://i695.photobucket.com/albums/vv312/r_chez_08/my%20mk1/IMAG0048-2.jpg)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/66image.jpg)
![M4tt13 in the usergroup ‘Regular’ M4tt13 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Do you have an item number for the led strip by any chance? The lack of light has always been a niggle that evades me until nightfall and it'd be nice to fix it!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/IMG_0038.jpg)
Website Manager
![lhasadreams in the usergroup ‘Moderators’ lhasadreams in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![lhasadreams in the usergroup ‘Paid Member’ lhasadreams in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![lhasadreams in the usergroup ‘Regional Hosts’ lhasadreams in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![lhasadreams in the usergroup ‘Administrators’ lhasadreams in the usergroup ‘Administrators’](https://vwgolfmk1.org.uk/themes/default/images_custom/3KoSCEK.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/4image.jpg)
![BIGNICKC in the usergroup ‘Paid Member’ BIGNICKC in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![BIGNICKC in the usergroup ‘Old timer’ BIGNICKC in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
I updated the bulbs but that looks blinding! (Pun intended)
Check out this item I found on eBay:
End time: Apr 9, 2013 11:09:17 PM
Item: 12 cm 12 led Lighting Strip ultra bright White for model rail building/coach 12v
URL: http://pages.ebay.com/link/?nav=item.view&id=300874112497
Alt URL: http://www.ebay.co.uk/itm/12-cm-12-led-Lighting-Strip-ultra-bright-White-model-rail-building-coach-12v-/300874112497
I had to cut the strip in half and slightly overlap the ends, and trim them a bit as the length was a bit long. Worked fine!
Lhasadreams, you could always try one of the multi led dash bulbs in there? You can buy smd ones or just ones with 3 square leds coming from the housing. I'll get a link if you want.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/92image.jpg)
![Cero in the usergroup ‘Old timer’ Cero in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/166image.jpg)
![GeeBee in the usergroup ‘Local’ GeeBee in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
Simple but very effective!
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/20160605_084816191_iOS.jpg)
![Hairyarse in the usergroup ‘Moderators’ Hairyarse in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Hairyarse in the usergroup ‘Paid Member’ Hairyarse in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Hairyarse in the usergroup ‘Regional Hosts’ Hairyarse in the usergroup ‘Regional Hosts’](https://vwgolfmk1.org.uk/themes/default/images_custom/MkOEmwK.png)
![Hairyarse in the usergroup ‘Local hero’ Hairyarse in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/themes/default/images/ocf_default_avatars/default_set/cartoons/matrix.jpg)
COTM Team
![aircooled1968 in the usergroup ‘Local hero’ aircooled1968 in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://i95.photobucket.com/albums/l155/andysmith1980/MK1%20Golf%20GTI/rsz_golfmk11.jpg)
![smudger in the usergroup ‘Local hero’ smudger in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/008_zpse29681e9.jpg)
![Melteddrummer in the usergroup ‘Moderators’ Melteddrummer in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![Melteddrummer in the usergroup ‘Paid Member’ Melteddrummer in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Melteddrummer in the usergroup ‘Local hero’ Melteddrummer in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
r_chez_08 said
Cheers for the compliments, smudger, send me the bulb housings with a self addressed envelope and order the strip to my address and I'll make you one foc.
You're a top man mate. I might just take you up on that
![Dom123 in the usergroup ‘Old timer’ Dom123 in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![cabfan in the usergroup ‘Old timer’ cabfan in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![:cool:](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cool.png)
![ramblin in the usergroup ‘Local’ ramblin in the usergroup ‘Local’](https://vwgolfmk1.org.uk/themes/default/images_custom/ylV8bhM.png)
![oldskool76 in the usergroup ‘Regular’ oldskool76 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
