WIndscreen drain question?
(In Topic #204083)
![davidfx in the usergroup ‘Newbie’ davidfx in the usergroup ‘Newbie’](https://vwgolfmk1.org.uk/themes/default/images_custom/QAXairo.png)
However the one question I had was……. Does the Scuttle panel have a drain hole in the centre under the windscreen rubber and does any one have a picture of it?
I should of taken a picture of it, but had to get the windscreen back in due to the weather. I just want to make sure I return it to the correct size and shape due to the rust around it, if it exists in the first place,
Thanks in advance
Oh and I don't know either because when mine was removed I wasn't there to see it but maybe another member will understand!
As above I removed my screen and repaired a few holes. However as I had as lot of rust around the centre hole under the rubber, I had to guess what size and shape it was and if it originally had one.Golf Cabrio said
Could you please explain why you're asking, what the issue is?
Oh and I don't know either because when mine was removed I wasn't there to see it but maybe another member will understand!![]()
So, I just wanted a picture of the flange of the scuttle panel that the rubber sits in (bottom centre), to check what needs to be rebuilt there.
Ive done a good search, but can't find any decent pictures.
![Screenshot_2016-05-05-20-21-44.png Screenshot_2016-05-05-20-21-44.png](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1462476969/uploads/attachments/572ba0a7d0ff5.png)
I welded and sealed the other holes I found, but this one was dead centre and looked to have straight sides as if it was pre formed.
It was badly corroded and I made a clean repair and left a hole in it.
If anyone can 100% confirm if a drain hole is normally there or not that would be great.
If not the screen and the welder will be out again.
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/zender%20avatar.jpg)
![bacardincoke in the usergroup ‘Old timer’ bacardincoke in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
Many thanks, that answers the problem.
Think I need to close the he up a bit more.
